Mini Cooper S brake light indicator came on. Can it be reset?
Old Sep 4, 2019 | 07:48 PM
  #26
Gary Gluz's Avatar
Gary Gluz
Changed sensors but light keeps coming back
Sorry to bring this topic from the dead. I have R55 2010 clubman. The brake sensor got damaged so I replaced it, the brake pads still have about 40% life on them. After resetting the brake light on dash it went away only to come back a few weeks later. Checked the sensor and it’s not broken. I purchased another sensor connected to the car but never hooked it up to the brake pad. Same story, the light went away and is now back even though the sensor is not installed on the pads and is not damaged. Getting the lift indicator and brake light on dash. Any advise as to how to resolve this problem would be greatly appreciated.
Old Sep 5, 2019 | 04:22 AM
  #27
Capt_bj's Avatar
Capt_bj
sensor circuit is activated by an open circuit created when the sensor wears down and breaks a wire.
if there is no sensor in the circuit, this also creates the open ....
if you want to leave the sensor off you need to jumper the wire ends together.
Old Sep 5, 2019 | 05:23 AM
  #28
Gary Gluz's Avatar
Gary Gluz
I understand that. That is why I put the sensor on but never installed it on the pads. The light went off initially but came back a few weeks later. Wondering what could be the cause.
Old Sep 5, 2019 | 05:39 AM
  #29
cristo's Avatar
cristo
Alliance Member
Two suggestions:
Check the connection to the sensors.
Unplug the sensors and check them for
resistance or continuity with a
multimeter.
Old Sep 5, 2019 | 08:39 PM
  #30
squawSkiBum's Avatar
squawSkiBum
Moderator
Did you check both sensors? Front driver side, rear passenger side.
Old Dec 13, 2022 | 07:35 PM
  #31
danielngho's Avatar
danielngho
Brake Pads Replacement before Service Light
I am going to replace the brake disk. and will be replacing the pads, does anyone know if I have to reset the brake service light even if this didn't turn on?
miniuy
Mar 18, 2017 01:59 PM
JAB 67
Tires, Wheels, & Brakes
27
Dec 23, 2011 07:35 AM
Powashiftin
Dec 23, 2011 06:50 AM
AllanS
Dec 20, 2009 04:47 PM
Blue Brummie
12
Apr 7, 2009 07:10 AM
