Snow Tire question
Old Oct 24, 2011 | 04:02 PM
Tikigod's Avatar
Tikigod
Snow Tire question
I think I may know the answer to this already but wanted to ask the experts before I decided one way or another.
I just recently took delivery of my Clubman S - with 16" all-season runflats installed. I have snow tires from my previous vehicle in my garage and they are practically brand new - only 4 months of use on them. Unfortunately, I have the feeling they may be the wrong size and un-usable on the Clubman.
They are Bridgestone Blizzaks WS70 - 215/60R16
I'll probably get another set of wheels for whatever snow tires I end up with - but was curious if I could use these tires ... or if I should craigslist these and start shopping for a whole new set.
Thanks!
Old Oct 24, 2011 | 04:44 PM
alwzopn's Avatar
alwzopn
I'm pretty sure that unless you have a big brake kit (or JCW brakes), then 16" wheels will fit. When I had an R56, I used 16" s-winder winter tires with no problem.
Old Oct 24, 2011 | 04:46 PM
Tikigod's Avatar
Tikigod
Mostly curious if those particular tires will work on my car, I have 16 wheels and tires already. Thanks
Old Oct 24, 2011 | 04:54 PM
Jim Michaels's Avatar
Jim Michaels
The 215/60/16 tires are 1.8" larger in diameter than the OE 195/55/16; thus would raise the ride height by about .9". I don't know if that would create a clearance problem over bumps with the fender above the tire. They're not too wide to fit on the 6.5" rim, but the narrower OE size would work better in snow. I would buy snows in the narrower size.
Old Oct 24, 2011 | 05:12 PM
booktrout's Avatar
booktrout
Tikigod,
Hey check this site out.. http://www.rimsntires.com/specs.jsp You can compare tires side by side.
Like Jim Michaels said, it looks like those Blizzaks will be nearly two inches taller than the OEM MINI tire/wheel combo.
Common OEM sizes.
Old Oct 24, 2011 | 08:07 PM
alwzopn's Avatar
alwzopn
Also helpful, especially for visualizing the differences:
http://www.miata.net/garage/tirecalc.html
Old Oct 24, 2011 | 08:39 PM
Tikigod's Avatar
Tikigod
great info - thanks for the information - looks like these tires will be going up on craigslist.
thanks again
Old Nov 16, 2011 | 12:20 AM
NavyNUKE's Avatar
NavyNUKE
So am I right in taking away from this thread that 215/60R16 is too large for a MINI and I should look elsewhere?
Old Dec 1, 2011 | 02:01 PM
Alex@tirerack's Avatar
Alex@tirerack
I'd agree.
Old Dec 1, 2011 | 02:25 PM
NavyNUKE's Avatar
NavyNUKE
Thanks! I ended up finding another set at 190/60R16.. and I now know that 215 would have been way too big, since I think these tires even rub the.. material? in the wheel well a little bit on sharp turns.
Kimolaoha
Dec 5, 2020 09:32 PM
woodstudio
Mar 15, 2020 08:28 AM
W0TM8
Dec 19, 2019 07:50 AM
col127
Aug 21, 2015 02:11 PM
Mini'mon
Aug 16, 2015 12:47 PM
