5mm spacers
Old Jul 20, 2011 | 05:19 PM
minimike21's Avatar
minimike21
5mm spacers
Ok so I have searched through a few forums and havent found much. I want to know if 5mm spacers would do anything for my stock 16in wheels on my Cooper s. Does it improve anything or should I have a different suspension set up. Or should I go to a bigger mm spacer. Sorry if this had been answered. Couldn't find it
Old Jul 20, 2011 | 06:23 PM
bobstah's Avatar
bobstah
improve anything?
the aesthetics of course...
i'll answer this question with an analogy
it's much like a push up bra that doesn't do too much. improves the looks a little?
go largee my friend!
Old Jul 20, 2011 | 07:45 PM
onasled's Avatar
onasled
The larger the spacer, the more tourque steer you will feel. May not notice it with a 5, but will with a 15.
Old Jul 20, 2011 | 07:49 PM
slinger688's Avatar
slinger688
Can improve cornering capability some as well because of the wider stance.
Old Jul 20, 2011 | 09:01 PM
minimike21's Avatar
minimike21
Haha like the analogy... Why would torque steer be more pronounced? Would putting spacers with stock suspension and stock 16s look any better? And I can see how cornering may be better...
Old Jul 20, 2011 | 10:21 PM
MiniBOL's Avatar
MiniBOL
I have them on and i have bigger wheels but aren't wide so I feel like I may have to look for 10mm but not quite sure if this will cause any issues. I thought I saw 8mm but not sure if they were H&R's. I do think they're more for aesthetics. Seen some in here with 15mm and they look really nice. Just dunno if there are any other adjustment once you go thicker. I'm a noob!
Old Jul 22, 2011 | 08:15 AM
rjtrout2000's Avatar
rjtrout2000
I have 5mm all around and I love the look. As far as handling goes, it may have done a bit as far as grip is concerned, but really the look was done to achieve a better stance without more expensive wheels! A cheap fix for now, until I can afford my new wheels.
I am installing some 15mm spacers on the front to see if I can induce a little oversteer. I figure if you can induce a bit more oversteer in a car that inherently understeers, then the car should become more neutral. Car is in the shop now, but when I get it back, I will snap some photos and post them up!
YaTuSabe
Aug 23, 2018 11:41 AM
theblackfalcon
Oct 19, 2015 05:22 AM
NickBchillin
Oct 5, 2015 05:11 AM
GAT
Oct 4, 2015 07:27 PM
Zew2888
Sep 29, 2015 08:49 PM
