2008 R56, what size 18" tires?
Old Jul 9, 2011 | 11:06 AM
srober910's Avatar
srober910
I have a 08 R56 and will be going to a 18" wheel. What size tires should I run? It looks like a 215/35/18 is the correct size, but I have seen some posts here with 225/40/18. Is there going to be a clearance issue with the bigger tire when I lower the car later? Any rubbing at all with the 225/40 ?
Old Jul 11, 2011 | 10:25 AM
Alex@tirerack's Avatar
Alex@tirerack
215/35/18
is a good fit. I have had rubbing with anything 25" tall.
Old Jul 11, 2011 | 11:37 AM
CHKMINI's Avatar
CHKMINI
I run 215/40/18 Summitumo's (from Tire Rack) with NM Lowering Springs and have not experienced any rubbing. I previously ran 35 aspect ratio tires and bent several wheels hitting medium sized potholes. The 40's have worked much better for me. My gallery has a few pics of the 40's.
Old Aug 16, 2011 | 07:49 PM
Smalls-'s Avatar
Smalls-
What tire size did you end up with? I'm wanting to get 225/40-18 for my 09 Clubman.
Old Aug 29, 2011 | 04:34 PM
619mini's Avatar
619mini
I've been running 215/40-18's for a while now and experienced minor rubbing. Thinking about going to 215/35's...
Old Aug 31, 2011 | 12:30 PM
Mach V Dan's Avatar
Mach V Dan
I've run 225/35R18. That worked well. I also tried 245/35R18. I had to space out the fronts (18x8 wheels, +45), and the tires hit the plastic fender arches at all four corners over bumps.
It gripped like crazy, though.
--Dan
Mach V
woodstudio
Mar 15, 2020 08:28 AM
jeremy_reyes94
Sep 6, 2019 07:53 AM
Zettinger
Aug 25, 2015 04:04 PM
Lex2008
Aug 16, 2015 08:33 PM
kwijmbo
Aug 5, 2015 09:00 PM
