Help! "Bites" on newly installed brake rotors?!
Old Jan 20, 2011 | 06:57 PM
Yangsen's Avatar
Yangsen
Hi all,
I just got new rotors for my JCW brake kit (Gen1 style) on my R53 MCS.
I had the regular JCW rotors previously and this time I went for the drilled and slotted ones.
After the install (rotors, pads, flush) the car drives and stops fine and I didn't notice any issue or noises. However, when I got home and try to take some pictures, I noticed there are, what looks like "carvings" or "bites" on the edges of my brake disks.
In P1, you can see that the edge of the disks are shaved/carved off by about 2.5" long. These bites are about 1/8" deep but only affect the inner side of the disks. Looking head on at the brake rotors, I don't see anything unusual as the outer surface of the rotors are perfectly rounded. These are seen on the inner surfaces of the disks and are seen on both front and left brakes. This only happened on 1 end of the brake rotors as rest of the rotors are smooth and normal, show in P2.
Can you guys please help explained what this is? Is this a install issue or could this have been manufacturer defects? I'm trying to figure out whether I go back to the guy who sold me the disks or the shop that installed it.
Old Jan 21, 2011 | 05:24 AM
Alex@tirerack's Avatar
Alex@tirerack
Looks like balalcing machiene work to me, part of this manufacturing process. I am sure Todd @ Tce can give us his take.
Alex
Old Jan 21, 2011 | 06:00 AM
Vollgas's Avatar
Vollgas
Looks like possible rubbing from dust cover on inboard side.
Old Jan 21, 2011 | 08:45 AM
Yangsen's Avatar
Yangsen
Alex
Hi Alex,
Thanks. I was just a bit worried since I did not notice these markings on previous (non-drilled and slotted) rotor disks.
Another friend also told me its very common on drilled and slotted rotors.
Old Jan 21, 2011 | 10:40 AM
yetti96's Avatar
yetti96
I too vote for balancing.
Old Jan 23, 2011 | 05:28 PM
toddtce's Avatar
toddtce
Correct. Simply a mill cut for weight removal for balancing needs.
adrchn
Aug 13, 2019 02:11 AM
Toolman
Jan 20, 2016 06:50 AM
squawSkiBum
Oct 2, 2015 09:21 AM
thebordella
Aug 31, 2015 01:37 PM
