Adapters? Good or bad?
Old May 30, 2010 | 08:27 PM
MiniSNewbie's Avatar
MiniSNewbie
I'm thinking of getting adapters for my mini that will change the bolt pattern to 5x112... Is this a good idea? I know guys on VW forums do it. I got these siiiiick RH wheels... Please help and get me out of my misery...
Old May 31, 2010 | 02:55 PM
e30r56's Avatar
e30r56
The problem with mini's and adapters is that we don't have enough room under the fender to run decent tires on wide wheels. Adapters are at least 25mm wide. What are the specs on your wheels?
Old May 31, 2010 | 03:14 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
Adapters can go as small as 18mm nowadays, but you're still correct. The issue is finding decent offsets to accept the adapter width. Many RH wheels are multi-fit meaning they are MEANT to be run with adapters so their offsets are super high to accommodate their fitment.
Other than that, no issues with adapters as long as you buy quality ones and install them correctly.
Old May 31, 2010 | 05:24 PM
MiniSNewbie
bolt pattern is 5x112, size 17x8, ET60.
Old May 31, 2010 | 05:45 PM
MiniSNewbie
Hey will this work? bolt pattern is 5x112, size 17x8, ET60.
Old May 31, 2010 | 06:08 PM
Rally@StanceDesign
Yes, that's perfect. As I mentioned earlier, many RH wheels have really high offsets so they can easily be used with adapters. It sounds like this is the case with the wheels you're looking at.
You'll want 20mm-30mm adapters depending on how you want the wheels to fit and whether you want to go with a little poke,as is common among the VW crowd.
Now the issue comes down to 5x112 adapters. They are only available for the first gen cars. The 5x112 adapters have a special offset slug which doesn't match the thread pitch of the second gen cars. Do you have a first gen MINI?
Old May 31, 2010 | 06:55 PM
MiniSNewbie
Yes, I do!!!! Do you think those wheels will look good with with stock suspension or should I lower it? I don't really want that to be honest becuse I do not want my car to be stiff...
Can you recommend any places where I could get adapters from?
Thank you sooooo much for your help!
Old May 31, 2010 | 07:47 PM
Rally@StanceDesign
Check out Adaptec Speedware (www.adaptecspeedware.com) . Tell them Rally sent you and that you need parts for a MINI. They make them completely custom so they are hubcentric and exactly the size/width that you need. They're good guys over there and one of the few that offer 4x100->5x112
It's obviously just personal opinion, but I think aggressive wheels such as 8's with low offsets look bad on non-lowered cars. The wheel gap just looks goofy when you run such an aggressive wheel setup. I say lower it....but it's YOUR car, so do what you want with it
Old Jun 2, 2010 | 01:03 PM
martinb's Avatar
martinb
My recommendation is to find wheels that fit the stock pattern. Why created problems for yourself?
Old Jun 2, 2010 | 01:14 PM
Rally@StanceDesign
What problems would be created? Adapters aren't that expensive and are trouble free.
The 4x100 wheel selection isn't the greatest...especially if you're not into the whole honda tuner style wheel that makes up most of the 4x100 market. Nothing wrong with adapting to another bolt pattern to access a whole new selection of nice wheels
Old Jun 2, 2010 | 06:02 PM
brutality's Avatar
brutality
If you think 4x100 selection isnt great, you would hate owning a Focus with 4x108 .... also you should post pictures when your done!!
Old Jun 2, 2010 | 06:14 PM
Rally@StanceDesign
Haha I have some friends with foci. Now THAT is a tough selection
Kimolaoha
Dec 5, 2020 09:32 PM
flredmini
Sep 3, 2015 07:15 PM
ludedude
Aug 10, 2015 07:16 PM
vballkid77
Cooper (non S)
Aug 10, 2015 04:44 PM
