knockoff jcw 113
on
knockoff jcw 113
http://cgi.ebay.ca/MINI-COOPER-SUMME...item27a7d4f488
I found these wheels for 600 dollars
But when I called they said they were not oem
The only difference I can find is the offset at 40
What is the oem offset
what will the diff be on the car with an offest of 40
on
link
http://losangeles.craigslist.org/lac...737283173.html
Really need to find out if this wheel will work with a 205/40/18 on coilovers
wont affect much at all. moves em out closer to wheel trim, but a et40 w a 7" wide wheel is nothing big
And on the ebay listing you posted, they are et52 if they are OEM , NOT 40...thats the tire aspect ratio
Will they work with coilovers??...depends on the coilover... your more likely to hit the spring perch with not enough offset, but those et40's should be just fine even with the larger bodied coilovers
PS id remove the link in your first post... everyone is being confused since they are real oem et52s
Wider stance, more roll resistance, better weight transfer, faster cornering. if they don't rub. Modern wheel bearings are strong enough the off balance weight should not be an issue. It moves the front center scrub radius, so it will effect steering feel. I would not worry about that either.
Can't tell you more without mounting them on a car!
08-19-2015 12:51 PM
08-12-2015 01:24 PM
