Camden, TPS, Mission Control. HELP Please
My wife just got a 2010 MCS Camden, with Mission Control. Anyway I was wondering if any body knows if I got winter wheels and tires without TPS sensors in them if the Mission Control would go crazy. I was wondering because I know that the warning light will be on and Mission Controls likes to warn you about almost everything like, no seat belt, e-brake, ect.
Any help would be greatly appreciated I don’t want to spend all winter hearing it tell me my tires are flat.
I guess I could turn mission control off or lower my tire pressure and drive around and check.
Also does anybody know if I can take the TPS sensors out of my factory 17 and put them into 18. Wasn’t sure I figure if the psi is the same it would be ok.??..
if you get tired of mission control, i'll take it
you can, i'm told, modify files on the SD card that contains the sounds, so you could perhaps find the ones (if there are indeed any about TPMS sensors) and replace them with blank noise...
[FONT=Times New Roman][SIZE=3][/SIZE][/FONT][FONT=Times New Roman][SIZE=3] [/SIZE][/FONT]
Clubber_Lang
Sep 23, 2015 03:43 PM
