Brake Sensor Light?
Old Dec 20, 2009 | 04:35 PM
AllanS's Avatar
AllanS
Brake Sensor Light?
I've replaced the rear brake pads this weekend & can't figure out how to turn off the dash sensor lite
thank you in advance for all help
have a safe holiday
Old Dec 20, 2009 | 04:47 PM
Capt_bj's Avatar
Capt_bj
have a safe holiday
sigh ... second time this month :: "The MINI uses a Brake Wear Sensor on the front left and rear right brake pads. When the brake pad wears down, the brake pad wear sensor is also worn down and will eventually trigger the warning light to alert you. Once the warning light is triggered, the wear sensor needs to be replaced. After replacing the sensor, turn the ignition key to the #2 position for around 30 seconds without turning over the engine...the light goes out!
Toolman
Jan 20, 2016 06:50 AM
thebordella
Aug 31, 2015 01:37 PM
fjork_duf
Tires, Wheels, & Brakes
Aug 16, 2015 04:38 PM
