Clearance Between Caliper & Wheel Barrel?
What is a safe clearance between the brake calipers and wheels? I have the JCW (R53) brake calipers and read that Motegis TrakLites 2's in 15 inch clear the JCW brakes. Well, they do, but with only 5mm to spare. The spokes are fine almost 2 inch clearance to calipers. Its between that barrel and caliper that is a tight fit.
Is it safe?
Do the barrels of the wheel flex past 5mm during track use?
Is it safe?
Wheels have been known to flex enough to get a FSAE into a state of positive camber, but then that was when the wheel wasnt nearly strong enough for the grip levels the car was generating. This usually results from the team making their own wheels.
This is not likely to be a problem on a street car.
Basically, the tight clearance on your car wont be an issue.
Think I got clearance then
More Info
My question was is would this 3mm clearance margin also apply between the caliper and wheel barrel?
Thanks, I guess I am fine then!!
squawSkiBum
Oct 2, 2015 09:21 AM
brother i
Tires, Wheels, & Brakes
Aug 23, 2015 01:15 PM
