PSA for OEM rear brake lines wear issue
Hello NAM Members. Take note and take a look at your brake lines.
While upgrading a local MINI's lines we discovered that the protection sleeve on the 1st Gen REAR OEM brake line had moved up the line and allowed the ebrake parts to wear a HOLE in the line
. See pics
Once the sleeve is back in the right spot zip tie the hose to limit the sleeve movement.
. See picsOnce the sleeve is back in the right spot zip tie the hose to limit the sleeve movement.
minimofo
Apr 4, 2016 07:36 PM
R50/53 Guidance on selling a 2005 S
Toolman
Jan 20, 2016 06:50 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
