New wheels and tires?
Okay I know this ?gets asked all the time about will this fit. So will this fit okay on my mini. I just bought a set of rotas 16x7 40mm offset, and 225/50 /16 reo1r's. The car is lowered on alta springs, stock camber. So hopefully it works. Would just like alittle input from you guys, thanks.
That's a fairly large tire (larger diameter than stock) but you should be fine. The wheel has a conservative width and offset so there really shouldn't be any major clearance issues.
They will raise the car a quarter inch though.
I figured it would raise the car alittle , but I wanted to make shure the tire would feel the wheel opening. I just didnt want to run to small off a sidewall on the tire.I kinds like a beefie sidewall. Thanks for the info Rally, Im glad you responded.You definitly know your stuff
sabjcw
Aug 14, 2015 07:40 AM
Rennfahrer555
Aug 13, 2015 09:07 AM
