Spacers??
Old May 13, 2008 | 09:37 PM
rjtrout2000's Avatar
rjtrout2000
Spacers??
What are the benefits of putting spacers on a car? I received a set of 5mm H&R spacers with the H&R lug bolts and thought about putting them on the front of my car. Any benefit from this at all?
Old May 13, 2008 | 10:18 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
If you don't need spacers then don't use them.
Spacers can be for looks to widen your stance but if taken too far out tend to overstress your wheel bearings.
Spacers that are very wide will need longer bolts or studs so that the wheel can be fastened on the hub securely. 3mm doesn't usually need more length but depending on your case 10mm usually do. If you have long tuner studs and open lug nuts that will work OK.
Spacers will allow for more clearance by pushing the wheel outward from the wheel wells and help clear the rear lower trailing arm and suspension parts.
Sometimes spacers don't allow hub centering rings to fit properly. Thicker spacers will need a small lip to help the ring when using aftermarket wheels.
Old May 14, 2008 | 12:35 PM
rjtrout2000
I have heard that running the spacer as large as a 10mm spacer is dangerous. Perhaps I will wait on the BBK and just upgrade what I've got. Thanks guys!
YaTuSabe
Aug 23, 2018 11:41 AM
theblackfalcon
Oct 19, 2015 05:22 AM
NickBchillin
Oct 5, 2015 05:11 AM
GAT
Oct 4, 2015 07:27 PM
Zew2888
Sep 29, 2015 08:49 PM
