Wheel torque confusion
My manual says 88 ft/lbs of torque but in another thread ScottRiqui says
My MCS is a 9/06 build, which is the exact month they reportedly switched to the 14mm bolts. So I'm not sure which ones I have and don't trust the manual (can easily see the user's manual not catching up on a change this small).
Help?
Help?
Help?
Help?
Either it is 12mm or it is 14mm.
Here is a picture of a 14mm (left side) to 12mm (right side) conversion stud- see the difference?
Notice the thread pitch is different too- 14x1.25 vs 12x1.5
If you are not any good at measuring you can take your bolt to a hardware shop and ask them if it is 14mm or 12.
If you have 12mm bolts then use 88 ft-lbs torque.
If you have 14mm bolts then use 103 ft-lbs.
Don't use something in between. Find out what you have so that you can torque your wheel nuts appropriately.
Dec 5, 2016 06:31 PM
Bruce/Fl
Aug 28, 2015 11:59 AM
minipopkart
Aug 13, 2015 05:22 AM
