16x8 offset 35
Old Feb 14, 2008 | 02:20 AM
mini_macky's Avatar
mini_macky
16x8 offset 35
saw these for sale locally
http://tsikot.yehey.com/classifieds/.../15869/cat/500
16x7 and 16x8 offset 35 (seems like these are meant for E30s)
will it fit?
Old Feb 14, 2008 | 11:52 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
will it fit?
16x7 with +35mm offset is likely to fit OK. Just go with a tire that is not larger than stock tire diameter. 205/50-16 will work.
16x8 is much wider than stock and +35mm offset is barely enough to clear the MINI suspension parts. You might need wheel spacers but this would push the rim further out. Again smaller tires would be better. 8" rim is heavier than 7" wide rim.
215/45-16 are possible tires for either 16x7 or 16x8 rims-
Fits rims 7 to 8" wide, 23.6" tire diameter
Falken Azenis Rt615 $89 each
Hankook Ventus Rs2 Z212 $90 each
bahman
Aug 6, 2016 07:19 AM
Chibi2
May 19, 2016 03:46 PM
Amberleigh MacIntyre
R55 :: Clubman Talk (2008+)
Nov 11, 2015 11:59 AM
vbmike
Oct 15, 2015 04:32 AM
