215/40/17 vs 215/45/17
Old Jul 12, 2003 | 05:55 PM
  #26
vespa's Avatar
vespa
Hey Alex,
Where did you find the 1140lb load spec for the MINI?
Old Jul 14, 2003 | 10:11 AM
  #27
Alex@tirerack's Avatar
Alex@tirerack
>>Thanks Alex, looks like 25lbs for the 17" s-lite. I have another question though, if I went 18x7.5or18x8 which wheels will work without spacers on the stoptech or brembo big brakes? Then also you rec a 225/40-18 size tire? :smile:
I'd have do address each wheel, and its individual design to know wich would fit. 215/35 remains for the tire size. All my 18's are 7.5 width.
Alex
Old Jul 14, 2003 | 10:19 AM
  #28
Alex@tirerack
>>Hey Alex,
Hi Vespa,
As mensioned in previos discussions there is a tire industry stadard guide used, called Bennett's tire guide. I use Bennett's to determine what the load bearing capacity of a given tire size.
Many manufactures have differing load claims, in any one size. Using Bennett's puts tire manufacture aside, and calculates the internal air chamber's volume, and proportinally how much load can be carried by a given inflation pressure and volume.
OE size on S at 33 PSI is 1140 lbs a tire.
Alex
Old Jul 14, 2003 | 02:41 PM
  #29
JBOO's Avatar
JBOO
I tried mounting 215/45/17 and 205/45/17 's on a 38mm offset wheel today and it did not work. Rubbing on the plastic in both cases. I do have a 30 mm drop, however, I thought I would be safe.
Old Jul 14, 2003 | 04:30 PM
  #30
Alex@tirerack
what wheels are you fitting?
Alex
Old Jul 14, 2003 | 10:37 PM
  #31
JBOO's Avatar
JBOO
I have team dynamics prorace 1's. they should have had a 45m offset, but I was sent 38 instead. tried mounting goodyear f1'a with no luck.
vbmike
Oct 15, 2015 04:32 AM
srhodes
Oct 8, 2015 05:17 PM
ilovepanerai
Suspension
Nov 15, 2004 07:43 AM
TwOMINIs
Tires, Wheels, & Brakes
Sep 30, 2004 11:42 PM
