Hub ID???
Does anyone know the id of the hub for a Spoon SW388 wheel (16 4x100 os45). I want to buy a set of hub rings for these wheels, can't find the spec anywhere, my micrometer doesn't go this big and I don't trust a tape.
I did find that if you use a torque wrench on the lugs they will center perfectly without the rings (small vibration gone) but I want to do it right.
The Cooper S hubs are 56.1? or is it 56.15?
Also, is it possible to get these in aluminum (if so where?) or do they only come in plastic?
Thanks in advance!!!
>>56 mm stub axel.
>>Alex
Thanks Alex:
You wouldn't happen to have the Spoon specs there in that database would you?
Do you think I should bother with plastic hub rings?
Forged wheels and plastic hub rings?
Or should I have a shop machine me a set out of aluminium?
>>Alex
Thanks Alex:
The Spoon is not a wheel I have data available on. The main diffrence is durabity in installation. A plastic ring is much easier to pinch and damaged when bolting on.
IMO, aluminum would be better from that standpoint, but as a centering pilot, plastic or alluminum will function identically.
Alex
Alex
BlueMCS
try contacting these guys
http://www.ipsracing.com/manufacturers/spoon/index.html
their a US dealer for Spoon. if i were to guess, i bet the native bore for the wheels is 73mm, but check with IPS to make sure.
another option is to take it to a tire/wheel shop and have them look at it. they'll probably have something to fit, since the MINI center bore is similiar to the Honda Civic.
