2006 jcw
2006 Mini R53: "Mk I" Mini Cooper S
  • 2006 Mini R53: "Mk I" Mini Cooper S - 2006 jcw - Used - VIN WMWRE33576TN29144 - 75,000 Miles - Salt Lake City, UT 84121, United States
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    $9,500
  • Location Salt Lake City, UT, 84121, USA
  • VIN WMWRE33576TN29144
  • Mileage 75,000
I purchased this mini as fun weekend car and have put minimal miles on it over the past year or two. During that time I’ve gone through the entire vehicle and addressed all common weak points and have added some modifications to add the fun factor of the vehicle without changing the factory look and reliability of the vehicle.
Recent parts installed
Mechanical:
- valve cover gasket
- timing chain guides
- timing chain tensioner
- oil pan gasket
- supercharger service (oil change and gaskets)
- 17% super charger pulley
- new belt
- cam position sensor gasket
- crank position sensor gasket
- oil filter housing gasket
- crankshaft seal
- ignition coil
- spark plug wires
- spark plugs
- power steering hoses
- power steering fluid housing
- aluminum coolant overflow
- coolant flushed
- thermostat and gasket
- map sensor and vacuum hard line hose
- throttle body gasket
- Alta super charger intercooler boots
- Alta air intake hose
- intake air filter
- coolant upper bleeder screw
Handling and suspension:
- Ireland engineering fixed camber plates
- cv boots replaced passenger and driver side
- spring seats, bump stops,  and dust boots
- sway bar end links
- power flex control arm bushings
- power flex front sway bar bushings
- upper hydraulic motor mount
- brand new firehawk Indy 500 tires (1000 miles on them)
- BBS RC style wheels 17x7.5
Cosmetic exterior/interior:
-OEM driving lights and OEM dash switch
-new wiper blades (aero blade)
- new passenger side roof trim
- new fender plastic arches
- XPEL XR Plus ceramic 35% window tint
- full vehicle wrapped in STEK dynored PPF
- roof wrapped in STEK dynowhite PPF
- rear seat delete
- new jcw aero grill
- new side scuttles and indicator lamps
- new jcw badge and mini cooper badge
- led license plate lamps
- led marker lamps
- weather tech floor mats
- tinted tail lights
Known flaws
- under bumper cracked
- hood has scratch in the paint if film is removed
- stereo volume **** is “temperamental” (steering wheel volume buttons work best)
- windshield cracked
I also have a box of misc parts and accessories that are not installed that I will be selling that we could work into the deal if interested.
Misc parts
WMW Rear sway bar and bushings
Jcw shifter ****
Euro rear tail lamps
center console/ arm rest
Old Dec 9, 2023 | 08:07 PM
RIPPER's Avatar
RIPPER
I offer 7k as it will cost 2500.00 to ship to MD
Old Dec 14, 2023 | 09:40 AM
t-w's Avatar
t-w
How come your car and this silver one sold on BAT a few years ago have the same VIN?
https://bringatrailer.com/listing/20...ooper-s-jcw-8/
Old Dec 14, 2023 | 09:52 AM
Jonny's Avatar
Jonny
[QUOTE=t-w;4667465]How come your car and this silver one sold on BAT a few years ago have the same VIN?
https://bringatrailer.com/listing/20...ooper-s-jcw-8/[/ it’s been wrapped.
Old Dec 14, 2023 | 10:29 AM
MCS4FUN's Avatar
MCS4FUN
Per online VIN decoder, the Dark Silver 2006 R53 sold on Bat by Geneva correctly corresponds to WMWRE33576TN29144
Old Dec 14, 2023 | 10:35 AM
2out2sea's Avatar
2out2sea
Hmm
Silver shock towers seem to confirm original silver. Door jambs and rear hatch too.
Old Dec 14, 2023 | 10:38 AM
MCS4FUN's Avatar
MCS4FUN
^^^ Likewise, a good catch which I'd missed...
Old Dec 14, 2023 | 10:54 AM
Jonny's Avatar
Jonny
it’s right in the description “full vehicle wrapped in STEK dynored PPF
- roof wrapped in STEK dynowhite PPF”
