2002 R53 Mini Cooper S 6 speed
For Sale2002 Mini R53: "Mk I" Mini Cooper S
Price
$1,000• OBO
- Location Hill, NH, 03243, USA
- Condition Used
- VIN WMWRE33452TD56597
- Engine 4 cyl
- Drive Type 2WD
- Transmission Manual
- Vehicle Type Hatchback
- Exterior Color Gray
Hello-
Looking to get rid of my R53. 6 speed manual 150k(ish).
I bought it a few years back from someone who put a lot into it and I took over the task. I drove it for about a year and when the front springs gave out on me I parked it. It was mid winter, I have no garage and was done putting any more money into it. It’s been sitting for over two years now. I threw a battery into it last year to start it up and the alternator was frozen and snapped the belt. Besides it is bottomed out from broken springs on a lowered setup (not by me) so it isn’t moving on it’s own. Good for parts or maybe repair if you are highly motivated.
There are a lot of newer parts on it.
Maintenance done:
Supercharger service + OEM gaskets
Crank o-ring
OEM Water pump + OEM coolant flange
and gaskets
OEM Oil pan gasket
OEM Valve cover gasket
Spark plugs ( NGK, 1 step colder)
MD plug wires and MSD coil
Serpentine belt ( AC deleted)
Transmission fluid (Redline)
Transmission bushings ( Powerflex)
Shifter bushings
New OEM shifter cables and hardware
Coolant flush + new expansion tank OEM
OEM Oil filter housing / OEM heat
exchanger + new OEM gaskets
Throttle body cleaned + OEM gasket
OEM Intake manifold gasket + OEM IM
horn gasket
OEM Thermostat
OEM timing chain
OEM Timing chain tensioner + new OEM bolt/gasket
Both CV shafts
Both 02 sensors
Exhaust manifold gasket
Exhaust header (OBX) I had all the weak
points re-welded.
Front brakes (Wilwood pads)
Both Ball joints
New clutch
New single mass flywheel
Fuel filter
Aftermarket bits.
Wilwood front big brake kit
Hotchkis H sport springs
M7 Strut bar with plates
Alta 15% pulley
Alta Intercooler boots
Alta intercooler plate
Alta Intake with K&N filter
Alta rear sway bar
Alta rear sway bar links
B&M short shifter
Megan rear trailing arms
Magnaflow Exhaust
Torque solutions lower engine mount
TSW engine damper
Powerflex engine mounts ( including
transmission)
Forge power steering reservoir
Sparco wheels 17x7
Hid headlights and fog lights
Windows are tinted.
Second set of 17" wheels included
Custom carbon fiber gauge overlays
