Suspension WHICH COIL OVERS ARE BEST?
Old Mar 7, 2007 | 07:27 PM
MINICHEF's Avatar
MINICHEF
Geting ready to convert over to coil overs, but want opinions and options.
i am looking at the Koni's, Tien, BC, Megan. and waiting on M7. I want easy external adj. This is my daily driver, but I push her hard and love the twisties Cost is a big issue.
Old Mar 7, 2007 | 07:48 PM
etalj's Avatar
etalj
In my opinion, the ones you want to consider are:
Leda
Bilstein PSS9
KW
M7
Each have their pros and cons. Is price an issue? Do you want more than 2 deg neg camber? Do you want durability?
Old Mar 7, 2007 | 07:56 PM
MINICHEF's Avatar
MINICHEF
Leda
Bilstein PSS9
KW
M7
price is an issue. will also be looking at camber plates. leaning twords IE adj.
Old Mar 7, 2007 | 08:32 PM
Wake|MCS's Avatar
Wake|MCS
no one mentions the eibachs. not sure how those are but they aren't too expensive. something to consider...
Old Mar 7, 2007 | 08:52 PM
SayGoodbye's Avatar
SayGoodbye
Cost was an issue with me as well. I found a set of KW Variant 1's on Ebay for a nice price. They are height adjustable only. Depending on your budget, you might look at the Koni Yellow Sport Kit. It is not height adjustable and lowers the car 30 cm, but you can change the stiffness of the ride. If your budget allows, go with the PSS9's...although at that price, there might be a few others worth entertaining like Leda's, KW Competition, or TSW. Good luck!
edit...we really don't know about the M7 coils yet...could be the best thing since 15% pulleys...which I hope is the case...or could be the next Megan/Pilo.
Old Mar 7, 2007 | 08:57 PM
ChrisW's Avatar
ChrisW
When you get ready to do it let me know and we can do your car and my car on the same day.
Old Mar 7, 2007 | 08:58 PM
Skiploder's Avatar
Skiploder
Leda
Bilstein PSS9
KW
M7
What are the pros and cons of the M7 coilovers? Have they even been released yet?
Old Mar 7, 2007 | 09:00 PM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
Originally Posted by SayGoodbye
...lowers the car 30 cm, ...
Sorry, I know it's a typo, but 30cm is a foot! Damn, I'd like to see a MINI lowered by a foot... I'm getting the Konis, cancel that M7 order, Peter!
btw, I'm one of those guinea pigs for M7. DFIC #23, coilovers #??.
cheers,
Old Mar 7, 2007 | 09:03 PM
SayGoodbye's Avatar
SayGoodbye
cheers,
You know what I mean...not that everyone else does...30 mm
edit...that's what Strongbow Cider does for ya!
Old Mar 7, 2007 | 09:28 PM
etalj's Avatar
etalj
M7 coilovers are relatively cheap. They offer a wide range of adjustments, 15 settings for stiffness. You can order custom spring rates, and have the dampers valved to suit. Out of the box, you can order 240/280 lbs/in springs, or 300/400. Shock shaft diameter is 50mm and thus strong.
One of the cons is that you can't adjust the height of the rear without changing the spring preload.
You can get these bundled with H-Sport Camber plates for a good price.
The m7s haven't been released yet. I think they will be in a couple of weeks.
m7s, if they turn out to be good, will be good value for money.
That said, Bilstein PSS9s and Ledas offer great value for money too, even though they are actually not cheap. They offer very close to the performance of the Ohlines etc, but still a price which is realistic....
Old Mar 7, 2007 | 11:14 PM
UKSUV's Avatar
UKSUV
I have PSS9's on the Mini and are pretty happy with them but my loyalty stands with KW's......hands down.
Old Mar 8, 2007 | 07:05 PM
MINICHEF's Avatar
MINICHEF
THAT WAS THE IDEA
Old Mar 8, 2007 | 07:31 PM
Dr Obnxs's Avatar
Dr Obnxs
The swap is easy...
but get an alignement afterwords. There's also a thread on a BC install. Special at $1000 for all four corners with camber plates included.
Another way is to do the marketplace, and see what comes up. You'll be able to get a better set for less price, and be as good as new with a rebuild.
Matt
Old Mar 8, 2007 | 08:11 PM
ChrisW's Avatar
ChrisW
THAT WAS THE IDEA
Cool, Oh and I went with Megans for what its worth. If you're going to the meeting tomorrow night and want me to bring them let me know.
Old Mar 8, 2007 | 09:38 PM
kyriian's Avatar
kyriian
i went with shocks and springs first, then went with a set of used FK Silverline Plus X coilovers, not the most famous, but essentially a KW equal, but with stainless steel body so it won't rust. so far i love it... and this is before corner balancing, and dropping it a bit more! i am hoping to put on stiffer springs in the spring with my modified Webb Plates, and hopefully i'd finally get the handling i wanted
Old Mar 13, 2007 | 09:09 AM
AZMCS's Avatar
AZMCS
Don't forget H&R! They actually make the springs for Bilstein PSS/PSS9 setups. I have had mine on for 20k miles with zero problems. No adjustment to compression/rebound, but on a daily driver I don't think this is a big deal. PM me if someone wants info on a good price for these.
ahmedalsurmi
Sep 12, 2015 05:59 AM
Da_jesus
Aug 25, 2015 04:20 PM
PaulWalliDumali
Aug 21, 2015 04:46 PM
sabjcw
Aug 14, 2015 07:40 AM
ki7hy
Aug 12, 2015 07:07 PM
