Suspension JCW Strut Nut Replacement..
Old Nov 24, 2006 | 12:19 AM
hd05's Avatar
hd05
I am changing out my suspension and need to get new nuts for the JCW strut brace, because i have heard that you cannot reuse the nuts...
I was reading a thread that was sending mixed messages on whether we can get the nuts from a hardware store or not... so, can we get them from a hardware store or do i need to order them from MINI????
Also, if i do need to order them, how much are they???
Thanks again everyone,
Allen
Old Nov 24, 2006 | 03:15 AM
Crashton's Avatar
Crashton
If you are talking about the three nuts on each of the strut tops, no you don't need to replace them. I reused mine when I installed my M7 strut brace & all has been fine. 13,500 miles of motoring without a problem.
Old Nov 24, 2006 | 06:58 AM
kenchan's Avatar
kenchan
just use some loctite blue if you're ****, but i reused my strut tower nuts
and also the nut on the piston shaft. btw don't over torque those strut
tower nuts. it only needs a snug tight with a small 3/8" drive (25-30lbs)
Old Nov 24, 2006 | 08:34 AM
hd05's Avatar
hd05
Awesome.. .thank you guys for the help..
Allen
Old Nov 25, 2006 | 10:16 AM
pbraun's Avatar
pbraun
Yeah, I agree about reusing the original nuts - I did on my 02 and it was fine.
On my new car, the nuts seem to be "short bolted", meaning a situation when a bolt is installed and the thread does not fully protrude through the nut. This is bad because it risks the thread stripping. The bolt or stud must protrude a few thread widths in order to secure the full gripping power of the retaining nut. I am going to find a jam nut, or some locking type shorter nut to redo the fitting.
Interesting related website someone recently showed me : http://www.boltscience.com/
Old Dec 3, 2006 | 04:57 PM
GoodFinder's Avatar
GoodFinder
I guess I should've figured there's a body of science on the subect of bolts! I've seen it's interesting how important the "hardware" can be when you're building up a trick setup. Thanks for sharing that site with us, Peter.
Old Dec 10, 2006 | 04:10 PM
KevinBaker's Avatar
KevinBaker
The JCW nuts (also used on the M3) are special ones, that have a thread that protrudes through the strut brace to make sure that they're all the way on. A group of us here in Australia bought some from the USA, worked out to about AUS$35 each for us (6 nuts), whereas locally dealers want about AUD$30 EACH for them!
Old Dec 23, 2006 | 11:35 AM
trackster's Avatar
trackster
I think the key to reusing them as others have said is to make sure you do not over torgue them. 25 ft lbs is the target.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
Dec 23, 2015 10:36 AM
minipopkart
Aug 13, 2015 05:22 AM
nomar116
Aug 10, 2015 11:24 PM
