Suspension Rear sway bar woes ...>>
Old Sep 25, 2006 | 06:05 PM
minibull2's Avatar
minibull2
Anyone experience and=y drivabilty issues after installing a rear sway.
I had a Hotchkis Comp installed a couple of weeks ago and since then the drive has gotten choppy.
Any suggestions?
Btw, I plan on installing front camber plates and having a 4 wheel alignment this week. I have a feeling that maybe the car is out of alignment.
Minibull
Old Sep 25, 2006 | 07:13 PM
XAlfa's Avatar
XAlfa
Which hole? I think the middle is as stiff as you need to go with JCW susp.
BTW, how do you like your MTH flash?
Old Sep 25, 2006 | 07:37 PM
ignote's Avatar
ignote
No problems here, but I have the 19mm bar.
Old Sep 25, 2006 | 07:47 PM
Motor On's Avatar
Motor On
Any suggestions?
A rear sway should make any changes I'd define as choppy. Just change how the car turns. If you think the ride change is a result of the install I'd suggest checking and make sure everything was reassembled properly.
Old Sep 25, 2006 | 07:48 PM
Mini Pete's Avatar
Mini Pete
I have the H Sport Competition bar and is set on the middle setting, and have experienced no problems at all. Probably the best mod to the car.
Old Sep 25, 2006 | 08:42 PM
ekim's Avatar
ekim
19mm h-sport on the stiffest setting and AOK on the street.
Old Sep 26, 2006 | 05:51 AM
UKSUV's Avatar
UKSUV
It definitely stiffens the car up. With doing every possible suspension mod on my car (except camber plates) my car is choppy to say the least. The biggest part was the PSS9's on full stiff. I am gonna back off the dampening eventually. I think that's normal.
Old Sep 26, 2006 | 01:26 PM
meb's Avatar
meb
A swaybar will affect ride quality. The stiffer the bar, the poorer (a word?) the ride quality. I could go on and on about why, but simply, ride quality suffers.
Old Sep 26, 2006 | 04:18 PM
minibull2's Avatar
minibull2
interesting.
I wonder if the trade off of better turn in and less understeer are worth the degraded ride quality.
Has this been debated?
Minbull
Old Sep 26, 2006 | 04:57 PM
kapps's Avatar
kapps
IMO, it's definitely worth it. I have my H-Sport comp bar on the softest setting and haven't noticed a drop in ride quality. The understeer is nearly dialed out though. The stiffer settings might degrade ride a little but they are also set to be on the oversteer side of balance. On the street, do you really want oversteer?
Old Sep 26, 2006 | 06:17 PM
minibull2's Avatar
minibull2
Currently the bar is set is the middle.
I think I will try the softest setting and see how it feels.
Thanks for all the info.
Minibull
Old Sep 27, 2006 | 03:08 AM
a610's Avatar
a610
Going from the middle to the softest setting definately helped my ride quality, along with making the car feel less twitchy at autobahn speeds
Old Sep 27, 2006 | 05:05 AM
Veni_Vidi_Vici's Avatar
Veni_Vidi_Vici
TANSTAFL! (there ain't no such thing as a free lunch). As meb has stated in many, many excellent suspension posts in the past, there is always going to be a quid pro quo when it comes to upping the performance of the suspension. Now, if you can convince yourself that better suspension performance feels better than a cushy ride, you're good to go.
Old Sep 27, 2006 | 05:10 AM
dmh's Avatar
dmh
The stock sway bars are more than adequate for street usage. If you autocross or track your car then you need to consider a sway bar change.
Old Sep 27, 2006 | 11:39 AM
minibull2's Avatar
minibull2
I agree about the compromise in ride quality vs. performance. This is why the factory is very conservative with suspension.
I like the idea of having a very aggressive driver for street as well as track. The car will eventually see track at some point.
After the front camber plates, sway bar setting changed and the alignment done, I will post my results compared to now.
Minibull
Old Sep 27, 2006 | 11:44 AM
Motor On's Avatar
Motor On
Many times on the road I have felt excessive understeer, which the sway-bar is supposed to null out.
Old Sep 27, 2006 | 12:16 PM
meb's Avatar
meb
...add a camber kit and you'll begin to like the stock rear bar.
Old Sep 27, 2006 | 12:19 PM
obehave's Avatar
obehave
There is a common misperception about understeer.
Even with a very stiff anti-roll bar you can enter a turn wrong and generate understeer.
Late braking is the biggest culprit among the "less than professional" driver club. Of which I am a member in good standing BTW.
Old Sep 27, 2006 | 12:59 PM
Veni_Vidi_Vici
Amen, brother. Camber + 225 R-compound tires = recipe for a Mini drift car
I'm seriously cosidering going back to the stock bar.
Old Sep 27, 2006 | 02:25 PM
minibull2's Avatar
minibull2
Any idea of how much negative camber is good for front camber without chewing up tires?
Mostly concerned for street use.
MiniBull
Old Sep 27, 2006 | 03:06 PM
dmh's Avatar
dmh
MiniBull
The stock setting: pretty much zero.
Old Sep 28, 2006 | 05:28 AM
Veni_Vidi_Vici
Again, it's how much you're willing to accept. I ran Yoko Parada Spec 2's for about 12-15k miles with -2.2ish up front. They coned and corded on the inside. I'm now running Avon Tech MS all seasons that are much harder. They've been on about 5k and show very little wear. Interestingly, I think they perform as well as the Yoko's but are about 3x as good in the rain. Go figure.
Old Oct 1, 2006 | 05:32 PM
minibull2's Avatar
minibull2
Helix Camber plates on and had alignment with new Nokian WM Tires.
Alignment specs are -1.5 up front.
After driving the car a a few days, I think it needs more -camber than the -1.5.
I think I will shoot for more like -1.75.
Minibull
Old Oct 3, 2006 | 09:22 AM
minibull2's Avatar
minibull2
Had the alignment shop put front camber to -2 and all is good.
The rear toe was out as well.
I love the settings in the front now.
Minibull
W0TM8
Dec 19, 2019 07:50 AM
pre shrunk
Aug 18, 2015 11:09 AM
Bennyboy
Aug 18, 2015 07:28 AM
nomar116
Aug 10, 2015 11:24 PM
OutMotoring
Aug 6, 2015 09:32 AM
