Suspension FSD motivation and the current step in the experiment (kinda long, sorry)
I've said it before - Koni's issue with lowering springs isn't the spring itself, but rather the bumpstops. Lowering the MINI and leaving stock bumpstops leaves too little travel for the FSD's to work properly. Run a shorter and properly engineered bumpstop and there should be no issue. So sayeth the product mgr at Koni I worked with to send my Subaru struts for fitment and prototyping. I asked him this exact Q and he gave me a straight, no BS answer.
That said, fixed camber plates make a nice addition, and it doesn't cost any more labor to add them when the struts are being changed.
Why would you not want the option to adjust camber if you are going to the expense of putting on camber plates? For an extra ~$150, you can get the adjustable plates. A little bit of negative camber (~1 degree of negative camber) will improve the handling of the car without affecting tire wear too adversely. I am not judging anyone's decision; just curious as to why they decided to go with the expense of camber plates without getting the adjustable ones. Maybe the previous generation of adjustable plates was not up to where they should have been; but the current generation of camber plates from Helix, M7 and the like seem to have addressed the problems of the past.
Assuming that was a true question and not a rhetorical statement; here are some reasons for choosing the fixed camber plate over current adjustable options. First the price difference is more than $150 and stating the obvious, if the adjustability is not needed, the extra money spent will be a waste. Second is the rubber carrier for the bearing; one more vibration absorber to make the ride more palatable. Third, very little alteration in ride height which is a good thing when using fixed height struts (like the original topic of this thread, FSDs).
More good things about the Ireland Engineering fixed camber plates, the mounting plate, not counting the additional 2.9mm thick bushing carrier, is very stout, 5.1 mm thick and 5.5 inches across compared to stock at 2.5 mm (the bushing carrier is integrated) and only 5 inches wide. For those with tower braces the bolts are longer so better thread purchase is capable.
Last edited by caminifan; Oct 4, 2006 at 10:39 PM. Reason: Missing sentance in original post
Scott, how much vibration are FSD owners experiencing with H-sport springs or other spring set-ups?
I've seen so much lately that I've shelved my plan to have you put the FSDs and my H-sport springs on. What solutions do you have, I'm sure you have some?
Paul
Paul
, but with FSDs and the stock SS+ springs, there is zero vibration from the FSDs. If the a/c kicks in, there will be vibration from the compressor, but that would happen regardless of whether the FSDs were on or not.
fixed plates and vibration
ok, first I have had the Ireland fixed plates on my car for 3000 miles now-with rotation at 3000 miles, tire wear is not any worse than it was. these plates raised my car a whopping 1/16, not even noticeable to the eye from a side view. the ride from the thicker rubber bushing in the IE fixed plates is truly the best my car has ridden as yet. they make it one step better, ride wise, and they also make it turn in verrrrrry nicely. Paul, my car has no adverse vibrations-so-I have no clue what folks are talking about. You need to come by and take mine for a drive in the country and freeways to see for yourself, then make your own decision.
1.0 to 1.25 degrees of negative camber is not going to kill the tires. 2+ degrees of negative camber is where you will notice premature wear on the inside edge of the tire tread. In this context, "notice premature wear" means the tread wear bars will appear on the inside edge of the tread, but you will have plenty of wear remaining on the outside edge of the tread.
ok, first I have had the Ireland fixed plates on my car for 3000 miles now-with rotation at 3000 miles, tire wear is not any worse than it was. these plates raised my car a whopping 1/16, [Emphasis added.] not even noticeable to the eye from a side view. the ride from the thicker rubber bushing in the IE fixed plates is truly the best my car has ridden as yet. they make it one step better, ride wise, and they also make it turn in verrrrrry nicely. Paul, my car has no adverse vibrations-so-I have no clue what folks are talking about. You need to come by and take mine for a drive in the country and freeways to see for yourself, then make your own decision.
