Suspension Koni FSD and HSport springs installed!
Old Jul 26, 2006 | 05:43 PM
  #51
idoc's Avatar
idoc
I had my FSD's and h-sport springs installed today. Initial impression... honestly I can't tell much of a difference.
Old Jul 26, 2006 | 06:05 PM
  #52
Larry Clemens's Avatar
Larry Clemens
What shocks and springs were you running before the FSD / H-sport install?
Old Jul 26, 2006 | 06:09 PM
  #53
idoc's Avatar
idoc
Just the original shocks and springs that came on the car! 06 MCSC with JCW.
Old Jul 26, 2006 | 06:15 PM
  #54
Larry Clemens
Did you have the JCW suspension?
I went from H-sport / OE shocks to H-sport / FSDs. These are my before and after ratings over various road surfaces and turns. (1 is bad, 10 is the best):
Before
  #55
Larry Clemens
Old Jul 26, 2006 | 06:16 PM
  #56
Larry Clemens
I went from H-sport / OE shocks to H-sport / FSDs. These are my before and after ratings over various road surfaces and turns. (1 is bad, 10 is the best)The first number is with OE shocks, The second number is with FSDs:
1. Smooth straight roads 7 8
2. Rough straight roads 5 7
3. Smooth sweeping curves 7 8
4. Rough sweeping curves 5 7
5. Expansion joints 3 6
6. Stability on acceleration from stop 5 8
7. Pot Holes 3 6
Overall I noticed a very significant change.
Old Jul 26, 2006 | 06:57 PM
  #57
spindoc's Avatar
spindoc
Would it make sense on a car that's tracked to use Koni Yellows in the front and the FSD's in the rear (along with aftermarket springs)? That way you'd have adjustability, but you could leave well enough alone in the back (as you wouldn't have to drill extra holes there, and it's hard to get at the Yellows in the rear to adjust them anyway). If this set-up is feasible, which springs would work well with it?
Old Jul 26, 2006 | 06:58 PM
  #58
idoc's Avatar
idoc
I have the convertible so it didn't come with the JCW suspension. I can't say I notice the same difference as you, although I have only driven home from the installer but it was a 2 hour drive. I still feel the same bumps as before.
Old Jul 28, 2006 | 08:31 AM
  #59
Bullydog's Avatar
Bullydog
Originally Posted by kenchan
tirerack says estimated availability 11/17/06?
WTF?!
I just ordered them from www.MiniMania.com
The price was $629.00
regular shipping takes 1 week.
Old Jul 28, 2006 | 10:15 AM
  #60
sandtoast500's Avatar
sandtoast500
I think you'll probably feel more of a difference if you change to the FSDs after quite a few miles on the stock shocks and HSports. I plan on spending my money in other areas until about 30k-40k miles. . .
my list seems to be growing though. . .
Old Aug 1, 2006 | 05:28 PM
  #61
2005MCS/KK's Avatar
2005MCS/KK
Actually, I think the reason why you cannot tell the different because you never try the stock shocks + HSport springs combo; now you feel the FSD shocks + HSport springs are similar to stock which means it does has a differnet.
Old Aug 1, 2006 | 06:52 PM
  #62
Larry Clemens
- I do not know what you are talking about. Sorry - Please explain.
Old Aug 1, 2006 | 07:17 PM
  #63
rkw's Avatar
rkw
He is referring to idoc, who noticed little change in the ride after changing from stock shocks and springs, to FSDs and H-Sports at the same time. He is saying that the H-Sports by themselves would have caused a harsher ride, but if the ride remained the same then it must have been the effect of the FSDs.
Old Aug 2, 2006 | 06:16 AM
  #64
2005MCS/KK's Avatar
2005MCS/KK
Thanks a lot RKW, I should have quote Idoc's post with the previous reply, sorry for the confusion.
Old Sep 22, 2006 | 01:29 PM
  #65
markusw17's Avatar
markusw17
I'm thinking about moving from my standard suspension on my 2006 Works (SS+), to FSDs with Eibach lowering springs.
Even with the Eibachs, will I still notice a considerably softer and more comfortable ride over rough roads/potholes etc. (not crashing/jarring like it is now!), and also better handling/less bodyroll when cornering/changing direction etc.?!
I want a softer/more comfortable ride, better handling/stability, and better looks (lowered). Will I get this with the FSDs/Eibachs combo?
Old Sep 22, 2006 | 02:05 PM
  #66
HAVNPHUN's Avatar
HAVNPHUN
The answer may lie in that your cabrio is carrying around extra weight (~175lbs) and your drop could be negating the effects of the FSDs. Check the Cabrio forum and you will see at least one person that noticed greater than a 1" drop with the hsports on a cab. Too much for the FSDs to work effectively I hear. You might get better results with the taller H&R lowering springs and FSDs on your cabrio, but no one has yet posted those results.
https://www.northamericanmotoring.co...ad.php?t=78577
https://www.northamericanmotoring.co...ad.php?t=76822
Old Sep 25, 2006 | 06:47 AM
  #67
2005MCS/KK's Avatar
2005MCS/KK
Just to report that, after driving my Mini S with the FSD/HSport combo for more than a month, I can tell you all it is so great! The car is still bumpy on tough road (tough road means tons of pot holes in Montreal) but not harsh at all! it definately improve the ride a lot! Highly recommand.
Old Sep 25, 2006 | 06:53 AM
  #68
PGT's Avatar
PGT
how much of a drop did you see?
Old Sep 25, 2006 | 11:31 AM
  #69
2005MCS/KK's Avatar
2005MCS/KK
It drops approximately 2/3 inche. I remember the tech told me if I want the car to be lower, he can simply used the stock bump stock and cut it in half... But I end up use the bump stop which came with the HSport springs, and it drops almost 2/3 inche, it is not an aggressive drop, but for sure it is lower than stock, and I find the car is much more enjoyable to drive now.
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
OZMDD
Aug 17, 2015 02:53 PM
Emnotek
Aug 13, 2015 05:47 PM
