Suspension Corner Balancing
Old Apr 8, 2006 | 09:59 PM
  #51
Dr Obnxs's Avatar
Dr Obnxs
Yeah
Originally Posted by matma92ser
Bushings? I thought it was a heim joint?
they're heim joints... But those wear out too.
Matt
Old Apr 16, 2006 | 09:14 AM
  #52
dmh's Avatar
dmh
NJ Race/Track Prep
Originally Posted by K9MINI
Thanks Guys!
Anyone know of a race prep shop in the NY/NJ around Bergen or Rockland County?
Yes, Precision Motorsports. Call Don at 732-259-5941 or email at dmh7443@optonline.net .
Of note, Precision prepares the J Stock and J Prepared BMWCCA class championship E30 M3 of John Paton. We have close to 20 years of race/track preparation in both BMWCCA and PCA.
Old Apr 16, 2006 | 02:42 PM
  #53
62Lincoln's Avatar
62Lincoln
Originally Posted by onasled
Actually, not really. One the front and one on the back would cure preload. But, if you want to keep the swaybar parallel to the ground then all four are needed.
Onasled, I've just noticed that my car on M7 lowering springs sits noticeably lower on the driver side (3/4" lower). Would preloading as described here be a potential cuprit? Or is it something more obvious that I haven't considered?
Old Apr 16, 2006 | 04:58 PM
  #54
meb's Avatar
meb
...did you forget to install something? That's a very big difference.
Old Apr 17, 2006 | 06:58 AM
  #55
62Lincoln's Avatar
62Lincoln
...as far as I know, no. The weird part is that this setup has been on the car over a year, and I only noticed the difference Saturday. So I'm wondering if something has changed (broken) to cause what I'm seeing.
Old Apr 17, 2006 | 08:52 AM
  #56
meb's Avatar
meb
Does the car drive funny? Is this semi-dry weight - without you?
Old Apr 17, 2006 | 09:54 AM
  #57
62Lincoln's Avatar
62Lincoln
I've done some additional digging, and it appears what I'm seeing really isn't new after all.
First, I went back and found my original 'before and after' measurements for height, and the current measurements are the same as they were a couple of weeks after the spring installation (the right rear is 1/2" higher than the left rear). The additional 1/4" I measured the other day on the RR is from measuring when the car's e brake was applied on a slight grade, and the car was bound up slighty. Doh!
The car had this same difference between the rear springs on the stock suspension, so it's not new. Is there any way to correct this factory condition, and therefore corner balance my car, short of coilovers?
I apologize for the dumb mistake on the ride height. Again, doh!
Old Apr 17, 2006 | 01:24 PM
  #58
meb's Avatar
meb
you have to check everything very carefully. One area that may or may not affect the mini - but certainly does with other cars - is when you perform the final torquing on all suspension components. On Honda/Acura products for example, you cannot perform the final toquing until the entire weight of the car is on the wheels. The bushings in these cars will definately bind. This will cause height adjustment problems and for sure, and, corner balancing difficulties.
I never ever torque any suspension component until the weight of the car is on the wheels - you have to get reasonbly close so threads aren't destroyed.
Then, check tire pressure, and for sure, re-check the build sequence in each of the struts. I've had problems in the past where my children interrupted my thinking and I forgot to add a washer or two or something. Unfortunately, the only way to isolate this is to start over, but from the most logical and least invasive places first. If these yield nothing, get your wrenches warmed up.
krohm
Sep 28, 2015 12:16 PM
rt808
Sep 25, 2015 01:59 PM
minimofo
Sep 20, 2015 05:17 PM
MINI-Madness
Sep 11, 2015 11:31 AM
Suspension Products
Sep 2, 2015 10:32 AM
