Suspension Show pics of your lowered MINI S!!!
Old Sep 17, 2007 | 09:47 AM
  #926
kenchan's Avatar
kenchan
konky- nice look! you go through wheels like toilet paper... how many wheels has that been for your car? (like 5th?!)
Old Sep 17, 2007 | 11:04 AM
  #927
kalbone's Avatar
kalbone
Originally Posted by Konky
yep KW V1's and no vibrations (until the inner tire wears from the retarded camber I have )
what camber u running in the rear?
Old Sep 17, 2007 | 11:11 AM
  #928
Ivano's Avatar
Ivano
I have just had to replace my front tyres for the same reason.... My tyres lasted 6 months and were worn right through on the inside... Because i have now raised the height the camber is not that bad so my new tyres should hopefully last longer.
I had to put 5mm spacers on the front as the lower spring platform on the KW'S was scraping on the inside edge of my rim, and wore the spring platform away slighty but no long term damage.....
Old Sep 17, 2007 | 12:25 PM
  #929
Rally@StanceDesign's Avatar
Rally@StanceDesign
Originally Posted by Ivano
I have just had to replace my front tyres for the same reason.... My tyres lasted 6 months and were worn right through on the inside... Because i have now raised the height the camber is not that bad so my new tyres should hopefully last longer..
Unless you had camber plates and made alterations that way....raising and lowering the front doesnt change camber a noticable amount and would not effect tires.
Old Sep 17, 2007 | 01:11 PM
  #930
sprp85's Avatar
sprp85
lowering minis in general doesnt change much up in fronts right?
but some said toe is the thing that changes when you raise or drop...
i'm almost done setting the height on my car tho hehehe will post then..
Old Sep 17, 2007 | 01:52 PM
  #931
Konky's Avatar
Konky
yep
S-lites
ASA AR1's
Porsche Phonedials
BBS Rz's
BBS RYII's
Old Sep 17, 2007 | 01:54 PM
  #932
Konky's Avatar
Konky
not sure the exact, over 2 degrees though
Old Sep 17, 2007 | 01:58 PM
  #933
70spop's Avatar
70spop
Originally Posted by Ryephile
Dang, Ryan! That looks GOOD. Even with the little bit of wheel gap, I can see how LOW the car is. Nice picture, too - it makes the roof look silver.
Edit: Your car is my desktop picture for a while.
I need to drop my car some more....
Old Sep 17, 2007 | 02:05 PM
  #934
kenchan's Avatar
kenchan
yep
S-lites
ASA AR1's
Porsche Phonedials
BBS Rz's
BBS RYII's
i got good memory.
Old Sep 17, 2007 | 02:06 PM
  #935
sprp85's Avatar
sprp85
Question for yall with Coilovers
How do you determine the height when you adjust em? In another word, how do you make all four corners to drop evenly? Do you guys count the threads on the coils? or measure X to Y ? Cuz I'm having a bit of difficulty making the corners to drop evenly.. (almost tho)
Old Sep 17, 2007 | 02:11 PM
  #936
Rally@StanceDesign
yah.....doesnt change much in front. My bet would be that toe was what was hurting his tires if anything.
Old Sep 17, 2007 | 02:39 PM
  #937
Ryephile's Avatar
Ryephile
BLUSH, thank you very much for the compliment!
--->sprp85: It's important to measure the preload desired and overall length of the damper [if you have coilovers with length adjust]. Pick a reference point on the shock body versus the spring perch, and measure as exact as you can for each side. From there you really should bring it to an alignment shop that has coilover experience and can corner-weight your setup with your weight in the drivers seat. You also need to pay attention to the amount of preload, as this determines where your ride height is within the range of suspension travel. The stock MINI suspension has a bit more than 2x the droop travel as up-travel, and this ratio seems to work very well with aftermarket coilovers too. Too little droop and the car will lift wheels very quickly in corners and on bigger undulations and create a tough-to-drive MINI. Conversely, too little uptravel and you'll be bangin' the bumpstops and bottoming out the shock too often, making a harsh, jarring MINI that has big mushrooming issues and snap oversteer if you hit a big bump mid-corner. The MINI's body isn't perfectly symmetrical from my experience with several MINI's, so don't freak out if the axle to wheel arch is an 1/8" off here and there. A more accurate way would be measuring the angle of your suspension arms to a reference plane on the subframe.
The other aspect of your question relates to motion ratio. The MacPherson strut in the front of the MINI has a 1:1 motion ratio, meaning that when the wheel moves 1", the damper moves 1". From my crappy measurements, I've found the rear motion ratio is in the neighborhood of 0.87:1. This means for every 1" the rear tire moves, the damper moves 0.87". This means a smaller change in preload or overall length is needed to achieve the same level positioning versus the front suspension.
I hope that helps a little bit,
Ryan
Old Sep 17, 2007 | 04:27 PM
  #938
kalbone's Avatar
kalbone
thats it??
Old Sep 17, 2007 | 05:30 PM
  #939
checkmate2006's Avatar
checkmate2006
A Year Ago
Today w/ M7 Springs
Old Sep 17, 2007 | 05:58 PM
  #940
gci's Avatar
gci
Nice drop, what springs did you use?
Old Sep 17, 2007 | 06:20 PM
  #941
70spop's Avatar
70spop
Originally Posted by checkmate2006
Today
Very nice!
Old Sep 17, 2007 | 08:18 PM
  #942
checkmate2006
I used M7 Sport Springs
Old Sep 19, 2007 | 09:36 PM
  #943
Wake|MCS's Avatar
Wake|MCS
Old Sep 20, 2007 | 12:15 PM
  #944
kalbone's Avatar
kalbone
Old Sep 21, 2007 | 01:16 AM
  #945
Guest's Avatar
Guest
Excuse the horrible image quality, I had to crank up the ISO on my camera to get enough light, it was dusk when the pics were shot .
Old Sep 21, 2007 | 01:33 AM
  #946
roofaS's Avatar
roofaS
^^Very nice indeed!
Old Sep 23, 2007 | 06:00 AM
  #947
Rally@StanceDesign
Today w/ M7 Springs
I'm assuming this is your car? Figured you'd like to see it.....saw it over on another forum
Old Sep 23, 2007 | 08:27 AM
  #948
smokeyjeo's Avatar
smokeyjeo
Bilstein PSS.
Attached Thumbnails Show pics of your lowered MINI S!!!-hill-drive-0425.jpg   Show pics of your lowered MINI S!!!-hill-drive-041.jpg
Old Sep 23, 2007 | 09:59 AM
  #949
Ivano's Avatar
Ivano
Originally Posted by smokeyjeo
Bilstein PPS.
Like the Brake/Wheel combo on the front. The brakes look massive against that size of rim... The car sits so well on the Bilstein's too
Old Sep 23, 2007 | 03:30 PM
  #950
Wake|MCS's Avatar
Wake|MCS
Bilstein PPS.
WOW
That looks GREAT!! Loving the color-matched BBS LM's
