Suspension H-Sport Springs & Rear Sway Combo
Old Sep 23, 2005 | 10:28 PM
jsound's Avatar
jsound
I was wondering what are the differences for coupling the H-Sport Springs with either the Competition (25mm) or Sport (19mm) Rear Sway Bars for the MINI Cooper S with the factory installed JCW package?
If my car is primarily a street "spirited" car, would it be best to go with the Sport Rear Sway Bar on the stiffest setting? I read on these forums that it is best to go with a 22mm bar for the MCS instead of a 19mm bar.
What about the Competition Rear Sway Bar?
What I basically want to achieve is an almost neutral handling car (if not possible, then very slight oversteer > understeer).
Thanks in advance!
Old Sep 23, 2005 | 11:12 PM
VoiD's Avatar
VoiD
the 25mm competition sway bar has a effective stiffness as a 22mm sway bar because it is a tubular bar.
I have the COmp bar in middle setting and like it. It still understeers a little.
Old Sep 24, 2005 | 05:27 PM
jsound's Avatar
jsound
Is your ride harsh? The Competition bar is coupled with the H-Sport springs right?
Old Sep 24, 2005 | 05:40 PM
m332is's Avatar
m332is
A sway bar only works in the corners. It will not make your rise harsher.
Unless you are taking your car to the track, I would think the comp bar is overkill.
Old Sep 24, 2005 | 08:25 PM
VoiD's Avatar
VoiD
I just have the sway bar for now. Springs are going in next month. I didn't notice any harsher ride.
Old Sep 25, 2005 | 01:02 AM
kenchan's Avatar
kenchan
mine's a 03 with H-Sports and Alta 22mm swaybar set at stiff. :smile:
Old Sep 25, 2005 | 06:08 AM
onasled's Avatar
onasled
Not really true. A stiffer sway bar in effect makes the car a bit stiffer also as both rear springs are now working together a bit more when only one tire goes over a bump.
Go with the Comp bar as it will give you better future options.
Old Sep 25, 2005 | 08:59 AM
m332is's Avatar
m332is
Sway bars work in the corners - they are not designed to do anything in a straight line. Go over a bump and see what you feel, then disconnect your bar and go over the same bump. I don't think you'll find diff.
As for set up, the best way to set up car is with proper rated springs and dampers. Sway bars are the final fine tuning. Most of us, for the street, start with sway bars ars they are cheaper and easier to install.
OK, going back to the original question/post - it was for "spirited" street driving. The still think that the comp bar is overkill for this application.
Old Sep 25, 2005 | 01:03 PM
onasled's Avatar
onasled
Sway bars work in the corners - they are not designed to do anything in a straight line. Go over a bump and see what you feel, then disconnect your bar and go over the same bump. I don't think you'll find diff........
Would very much have to disagree with you here.
Old Sep 25, 2005 | 01:19 PM
m332is's Avatar
m332is
OK, we can agree to disagree! No hard feelings.
Old Sep 25, 2005 | 03:28 PM
kenchan's Avatar
kenchan
i agree that the comp bar would be overkill for street.
i agree that the swaybar will make a difference in ride when
one side of the car goes over a hump/dip/bump...but if both
sides of the car enter the hump/dip/bump at the same time,
it will make no difference in ride.
for street, i think we can say that swaybars are more for
cornering enhancements over straightline stability. straightline
stability is achieved by the use of better glasses and no drinking.
Old Sep 25, 2005 | 03:47 PM
m332is's Avatar
m332is
agreed.
W0TM8
Dec 19, 2019 07:50 AM
pre shrunk
Aug 18, 2015 11:09 AM
Bennyboy
Aug 18, 2015 07:28 AM
nomar116
Aug 10, 2015 11:24 PM
OutMotoring
Aug 6, 2015 09:32 AM
