Suspension How does a sway bar work?
Old Jul 11, 2005 | 01:00 AM
neilgj's Avatar
neilgj
Being a novice, I found this quite interesting. So I thought perhaps others may be interested, too. Here is a description I found detailing sway bar operation.
http://forums.vwvortex.com/zerothread?id=148337
Please forgive that it was posted to a VW forum :smile:
Old Jul 11, 2005 | 10:35 AM
kenchan's Avatar
kenchan
so that's how it all worked. I thought I had to put a new coin in each time
I took a corner. nice find.
Old Jul 11, 2005 | 02:53 PM
ZenAudio's Avatar
ZenAudio
Nice info
at least it sounds good, as I'm a novice in that area as well.
Mike
Old Jul 11, 2005 | 03:17 PM
MGear's Avatar
MGear
Okay that was really excellent at explaining how sway bars work, the next question is if we want to add sway bars to our cars how do we choose what is the best set up, or is their a best set up
Old Jul 11, 2005 | 06:33 PM
kenchan's Avatar
kenchan
yeh, there's only a "best" setup for your application, never in general.:smile:
Old Jul 12, 2005 | 06:02 AM
meb's Avatar
meb
Kenchan, my thoughts exactly!
I would say stay away from anything too radical and then experiment a lot with adjustments; swaybar settings, geometry, damping etc.
Old Jul 12, 2005 | 07:50 AM
orthomini_jr's Avatar
orthomini_jr
Personally I'd stay away from swaybars all togeather.
Old Jul 12, 2005 | 08:18 AM
chrisneal's Avatar
chrisneal
Yeah, remove the stock one, too!
Old Jul 12, 2005 | 10:31 AM
kenchan's Avatar
kenchan
you can do that?!
Old Jul 12, 2005 | 01:32 PM
minie's Avatar
minie
why stay away from swaybars?
Old Jul 12, 2005 | 02:11 PM
meb's Avatar
meb
That's odd advise. Why say you?
I agree, that swaybars should be used to FINE tune the set-up and here they can be extremely beneficial. And by fine tune I mean that springs and dampers, in that order, should be selected first for a single purpose; road or track. I would agree that under some circumstances one might be able to do without a front bar on a front wheel drive car or a rear bar on a rear drive car. My final set up with my 1981 Ford Fiesta had no front bar.
I can understand your comment from a narrower perspective, but wieght transfer is aided by sway bars too...with little other ill affects if approached properly; too much bar/roll stiffness can be bad. However, roll stiffness distribution is can be fined tuned with swaybars without adding to damping or springs rates; too much stiffness here is bad too.
W0TM8
Dec 19, 2019 07:50 AM
minipopkart
Aug 13, 2015 05:22 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
