Suspension 2005 Rear Suspension Adjustment
Old Jun 16, 2005 | 07:45 PM
JPit's Avatar
JPit
Recently I lowered my MCSC with M7 springs. I knew the rear camber would be somewhat effected so I took it in to see by how much. The rear camber was measured to be -2.5 degrees on the left and -2.3 on the right. It turns out though that the rear cam bolts don't allow for too much adjustment and were already set to near their positive limit. I had to settle for -2.3 on each side. He did say however that an aftermarket company shouldn't have too much trouble developing a cam that would provide more adjustment. Would save the expense of buying control arms.
Old Jun 16, 2005 | 09:48 PM
AC_MINI's Avatar
AC_MINI
I added ACA in the rear after lowering my MCS and that help.
Old Jun 16, 2005 | 10:33 PM
markbradford's Avatar
markbradford
Do you think there's enough adjustability there to dial in a degree of extra negative camber for the track even without lowering?
Old Jun 16, 2005 | 11:17 PM
JPit's Avatar
JPit
There is a good chance that you will be able to pick up a degree of negative camber. While I was watching him adjust the camber he was able to get a negative 3.3 before moving back in a positive direction.
Old Jun 16, 2005 | 11:34 PM
markbradford
NICE!
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
ebowling
90
Aug 4, 2019 09:15 AM
mdutton11
14
Oct 26, 2015 01:47 PM
Minibeagle
Aug 13, 2015 10:00 AM
