Suspension Clunk in the rear after installing rear sway bar
Old Feb 28, 2005 | 09:22 PM
  #26
ScottinBend's Avatar
ScottinBend
Hope this is the fix !
Old Feb 28, 2005 | 09:35 PM
  #27
Verruckt's Avatar
Verruckt
I have the same problem, and it sounds like the same bar (with stops and all). Eric at Helix went over the whole thing and couldn't find anyhting loose. Mine is not the end links. I know this because I had that issue as well, and corrected it. I'm interested to hear if this adjustment permanently fixes the problem. Mine is driving me nuts!
Old Mar 1, 2005 | 11:03 AM
  #28
kenchan's Avatar
kenchan
I was about to say perhaps your swaybar was rubbing the spring, but I was like naaawww, no way and didn't post. I'll make sure next time to speak my mind more...
Originally Posted by Azwed
Ok so today I put the MINI back on my lift rechecked all the bolts and nothing is loose.
I loosened the sway bar to frame bolts and the aluminium clamps and double checked the centering of the bar. I think the bar was a little to the drivers side by my measurment so I gently tapped it more towards the center with a dead blow plastic mallet.
I lowred the MINI some onto wooden blocks and preloaded the suspension as much as i could then retightented the bolts. I think the bar was making contact with the driver side spring. I can see some light scraping marks on the spring. I put some yellow tamper seal on the place and will check it again in a few days.
So far I have not hear any loud clunking since doing this just normal bump clunks.
Toolman
Jan 20, 2016 06:50 AM
nomar116
Aug 10, 2015 11:24 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
