Suspension Problems "losing" alignment
Old Feb 17, 2005 | 08:47 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
A while ago i noticed that my front passenger side tire was wearing a bit unevenly and my steering wheels was wiggling occasionally. The problem was obviously alignment. So i took it up to a local shop and just had them set the front alignment to stock. It was a short process, and i just wanted them to check everything out. They said it was all cool, and i was on my way. The car felt great, and so i drive back to school ( a two hour commute). Now after about a month or a little more, my alignment is way off again on that front passenger wheel. I didnt hit anything major, and avoided as many potholes as possible. I havent tracked it or driven it that hard. Maybe im wrong, but i didnt think i should be able to "lose" my alignment so quickly.
Can anyone shed some light on this confusion?
Old Feb 17, 2005 | 08:53 PM
MyPocketRocket's Avatar
MyPocketRocket
It may be as simple as wheel nuts went loose.
Old Feb 17, 2005 | 09:03 PM
Rally@StanceDesign
I have checked thos regularly...they are all torqued to OEM spec. The tires are balanced evenly too
Old Feb 18, 2005 | 07:22 AM
meb's Avatar
meb
Ball joint(s)? Tie rods? Steering rack bushings? Bad damper?
Old Feb 18, 2005 | 08:16 AM
Rally@StanceDesign
Those were my thoughts as well....i am installing new dampers so plan on checking all of that when im in there, i was just wondering if maybe it was a common problem among cars or even among minis.
Old Feb 18, 2005 | 08:31 AM
sfjames2's Avatar
sfjames2
Hey, jlm has mentioned that he's experienced premature wear on the lower outer ball-joints, twice. That would cause this kind of wear probably.
Gabe3
Tires, Wheels, & Brakes
16
Apr 16, 2016 07:55 AM
maestro39
Oct 27, 2015 02:38 PM
Drumsound
Sep 4, 2015 04:53 AM
L3Mix
Aug 26, 2015 07:00 PM
ASRman
Aug 13, 2015 09:33 AM
