Suspension Suspension recommendations
Old May 26, 2026 | 07:17 AM
12R57s's Avatar
12R57s
I just installed new wheels and tires a few weeks ago (flush offset stock height), going over the sunk in divets in the road I get my rear end rubbing the fenders. Does anyone recommend any aftermarket suspension thats a little stiffer but not too harsh? Was thinking koni yellows. I believe they have adjustable dampening?
Old May 26, 2026 | 07:46 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
What are the wheel specs and tire size?
Old May 26, 2026 | 07:51 AM
12R57s's Avatar
12R57s
17X8 +35 with 215/45/17
Old May 26, 2026 | 08:00 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Compared to the stock setup, that is a pretty aggressive wheel fitment.
https://www.wheel-size.com/calc/?whe...cl=30mm&sr=0mm
My suggestion is to add a bit of rear wheel camber to pull the top of the tire back under the fender. Stock camber setting is -1.5°. I would go to -2° on each side, which should help with the fender rubbing. As longa s the toe alignment stays in spec, tire wear shouldn't be affected. To balance out the rear camber change, do a search for adding front camber by removing the plastic button on the strut mount.
If you want firmer shocks, I would recommend Bilstein B6s with the stock springs.
Old May 26, 2026 | 08:19 AM
12R57s's Avatar
12R57s
Awesome! thanks for the info much appreciated.
Old May 27, 2026 | 09:43 AM
Scoobaru2010's Avatar
Scoobaru2010
Solid advice @njaremka
You can pickup adjustable control arms on amazon rather cheap, same exact ones upper and lower. Maxpeeding rod branded, built solid haven't had issues in years even with aggressive tracking.
Another note to the rear end trailing arm bracket / bushing bracket has some adjustment. Combined with adjustable control arms there is endless amounts of adjustment. I think there is 1/4" to 1/2" adjustment alone on the bracket. Simply loosen the bolts a bit and you can slide this bracket in and out. This will change the rear toe but combined with adjustable arms you can adjust that back out.
Best of luck
Old May 31, 2026 | 06:35 PM
bsgesch's Avatar
bsgesch
All this and still no pics?
Old Yesterday | 04:43 AM
12R57s's Avatar
12R57s
Here are some shots!
Old Yesterday | 06:31 PM
R57dropstick's Avatar
R57dropstick
I replaced my rear adjustable upper control arms to help dial in the camber closer to spec. The right rear was about -2.3 (as good as he could get it), but he was able to get the left rear in spec to about - 1.4. He suggested I get the adjustable lowers. After driving it around for a couple months, I could hear one of the rear tires rubbing the plastic fender lip when compressed due to dips in the road. Well I'm glad I didn't buy those arms. The aftermarket 17" wheels offset pushed them out further than stock. So I went back and had him add more neg camber to the left rear. Oddly enough, the right rear came in to about -1.9. No more wheel rubbing, so I'm thrilled.
DonPippins1
Apr 28, 2022 09:51 AM
Husam Hammadi
Jan 1, 2014 03:13 PM
AkFarina
Suspension
Jan 28, 2009 07:46 PM
2packt
Tires, Wheels, & Brakes
Nov 29, 2007 03:48 PM
fix8ted
Suspension
Sep 1, 2006 07:15 AM
