Suspension JCW F56 w/ BC Coilovers Rear Camber setting?
Old Dec 15, 2024 | 05:39 AM
Rocketrob's Avatar
Rocketrob
JCW w/ BC coilovers and adjustable rear control arms, 18x8.5 rims
Is there any benefit in increasing negative camber on the rear beyond stock setting?
Old Dec 16, 2024 | 05:47 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Daily driver, or track rat? Those have adjustable front camber plates, correct?
For a daily driver, I would shoot for -1.75° each side in the front, and between -1.75° and -2.0° in the rear.
Old Dec 16, 2024 | 06:16 AM
Rocketrob's Avatar
Rocketrob
Good Stuff!
Yes adjustable fronts.
I guess I am building a "road driven track rat", not to concerned about tire wear as the tires are the cheapest component on the car
I was thinking about 2 degrees negative for the rear.
Thank you for weighing in!
Old Dec 16, 2024 | 06:27 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
-2° camber in the rear will be good. Minis gain rear a lot of negative camber under compression in the rear, which helps keep the rear planted. Not going crazy with the rear camber will help keep the car stable and predictable. Going slightly lower front camber will keep the front from gripping too much, and giving a slightly neutral feel.
Do you also have an aftermarket rear sway bar?
Old Dec 17, 2024 | 03:40 AM
Rocketrob's Avatar
Rocketrob
Yes a 25mm adjustable bar if I recall correctly.
Thank you!
Old Dec 17, 2024 | 05:08 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
In my opinion, with a bigger rear bar, keep the r camber -0.25° to -0.5° more than the front. So if your front end up at -1.75°, then set the rear to -2.0° or -2.25°. The bigger rear bar will make the rear loose, but the additional camber over the front will keep it in check.
njaremka
Feb 12, 2017 05:00 AM
Suspension
11
May 11, 2015 05:22 PM
DOtheDEW
Mar 14, 2015 02:21 PM
shredthegnar
Suspension
Sep 26, 2012 11:55 PM
HI-MINI
Hawaii
17
Aug 19, 2003 09:10 PM
