Suspension Rear Koni Shock for MCS
Old Feb 2, 2005 | 06:33 PM
LeftyS7's Avatar
LeftyS7
Can I borrow a Rear Koni sa Shock for MCS?
Anyone have a rear Koni single adjustable shock that I can borrow? Leda will match its characteristics if they can get one and I don't want to buy one for them to copy. My plan is to use front Konis and rear Ledas which can be adjusted from the bottom. Thanks.
Old Feb 3, 2005 | 08:17 AM
LeftyS7's Avatar
LeftyS7
In the past some poeple have posted that they removed their Konis. Can I borrow a rear one? I'll pay a deposit. Thanks.
Old Feb 3, 2005 | 10:08 AM
meb's Avatar
meb
Why don't you ask Leda to buy a damper from Koni so they service your account? Seems a bit backward. I'm also sort of surprised that they're no 'up' on the competition...
Call True Choice 800-388-8783 and ask to speak with Greg or Frank - Greg first. True Choice is the only company authorized to re-build and modify Koni dampers. I've worked with these guys in the past with two other cars. This is their busy season; they are getting ready for the first events and so, may not have lots of time. Be very specific with your questions with regards to the Koni damping. They may be able to give you the rates over the phone. My dampers were for a different application, so they won't help. I just threw four away.
By the way, True Choice will build you completely custom dampers if you know what you are doing.
Old Feb 3, 2005 | 02:36 PM
LeftyS7's Avatar
LeftyS7
Thanks, I like Konis and have had good experiences with them and was aware that companies can convert them to DA as well as re-work them but one of the adjustments would still be on the top of the shock which is inaccessible in the rear. I don't know if they'll want to give me info for a competitor to use.
Old Feb 3, 2005 | 05:14 PM
meb's Avatar
meb
I remeber reading somewhere that one of our sponsors pre-sets the rear Koni based upon their testing. Obviously that removes some of the reasoning for the purchase.
My last koni dampers were re-valved to SST - show room stock - to work with a set of 400lb linear rate Eibachs. They controlled the springs really well. Very stiff set-up. You can also have True Choice make your dampers adjustable for bound and rebound. You can ask them to shorten the damper body. You can ask for almost anything...$$$$$$$$$$$$$$ Double adjustable SST valving ran about $2,000.00 four years ago, for four dampers. $500 each.
Old Feb 3, 2005 | 11:48 PM
LeftyS7's Avatar
LeftyS7
I don't want to spend more money for shocks I want to spend less and one STILL would have one adjustment at the top where it is inaccessible.
Old Feb 4, 2005 | 08:06 AM
LeftyS7's Avatar
LeftyS7
I'm now told that LEDA shocks won't work with the MINI springs. The shock body diameter is too large.
Toolman
Jan 20, 2016 06:50 AM
blackie
Aug 25, 2015 09:08 PM
Emnotek
Aug 13, 2015 05:47 PM
nomar116
Aug 10, 2015 11:24 PM
dyeLucky
Aug 7, 2015 07:10 AM
