Suspension Koni Yellow compatible with Powerflex rear mount bushings?
Old Jul 20, 2020 | 08:56 PM
mslatter's Avatar
mslatter
Struts are due and I want to upgrade to Koni Yellows. In the interest of "what else should I do while I'm in there" it seems I should consider my rear strut bushings as well (I'm replacing the front mounts with Eibach camber plates so no need there).
I always read that there's a part that needs to be drilled out to accomodate the Konis, and now it makes me wonder whether the Powerflex bearings are compatible with Koni Yellows. Anybody with experience on matching these parts, I'd appreciate your advice. Thanks in advance.
Old Jul 21, 2020 | 01:56 PM
JAB 67's Avatar
JAB 67
In one spot you refer to 'bushings' and in another 'bearings.' Do you mean the bushing at the front of the rear trailing arm? I recently installed Powerflex inserts in that location, and can not imagine that Koni yellows would complicate things there.
Old Jul 21, 2020 | 03:12 PM
mslatter's Avatar
mslatter
Thanks. I meant bushings when I said bearings. And I'm referring to the (usually) rubber bushing in the top mount for the rear strut. This piece: https://www.waymotorworks.com/powerf...-bushings.html
But while I got your attention: did you like the PF bushings on the RTA? I've redone the front-end suspension with PF and it was a rewarding improvement.
Old Jul 21, 2020 | 03:58 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes you can use the Powerflex rear upper shock mount bushings with the Koni Yellows, you will just use the new sleeve that comes with the Konis in the bushings.
You will still need to drill the spring top hat to fit it on the shock shaft though.
Old Jul 22, 2020 | 06:29 PM
mslatter's Avatar
mslatter
Thanks for the response, and you've earned my business yet again.
GeneralSpecific
Aug 26, 2019 06:27 AM
MassMini
Suspension
May 22, 2017 09:10 AM
MassMini
Suspension
Oct 5, 2016 08:24 AM
Mindspin311
Suspension
Apr 24, 2013 08:19 PM
YMINI
Suspension
14
Nov 22, 2010 07:24 AM
