Suspension JCW (red) springs lifted my R56!?
Old Mar 28, 2020 | 05:57 PM
eSienk's Avatar
eSienk
Last October I installed a set of VIN matched JCW springs and Koni yellows on my Non-S R56 (no pano). Measurements before and after show it raised the ride height an average of 1/4" at each corner. I'm assuming that I screwed something up as the springs advertise to lower the vehicle.
I reused all the old components like spring isolators, upper mounts, and the like. Did I miss something? Can anybody check my spring part numbers against my VIN to make sure I have the right springs? Thanks!
Old Mar 28, 2020 | 08:15 PM
thebmwnut's Avatar
thebmwnut
Only thing that I can think that could have gone wrong is maybe the spring ends are not properly in the rubber spring mounts and the top mounts have a offset where the end of the springs and rubber sping mounts sits up against. Check that first
Old Mar 28, 2020 | 09:03 PM
thebmwnut's Avatar
thebmwnut
I have 2012 base mini no sunroof only option is sport seats. I bought mine 3 years ago I don't know the part numbers but here is a picture of the paint codes and a picture of how the spring and upper mount should line up. I could measure how think the coils are if that might help. The cooper S is about 150 lbs heavier then a base and from what I was told most or all is on the front end so I would not think the rear would get affected much.
Old Mar 28, 2020 | 09:04 PM
thebmwnut's Avatar
thebmwnut
Old Mar 29, 2020 | 04:15 PM
deepgrey's Avatar
deepgrey
The difference in weight shouldn’t matter because the springs are VIN matched.
You might have better luck over in the second gen forums.
Old Mar 30, 2020 | 04:28 AM
eSienk's Avatar
eSienk
Yeah, noticed that. My bad. Is this thread movable or should I just repost?
Thanks for the pics bwmnut. I'll compare my stripes.
Old Mar 30, 2020 | 04:23 PM
deepgrey's Avatar
deepgrey
I had a thought, though I don’t think it would make up for the full amount of difference, and certainly not at the front. When I went to Swift springs on Koni Yellows at ~65k miles, the lower bushings on my stock rear struts were shot and deflected upwards a bit. They were bad enough that I was getting rub at full compression when I switched to 205/55R15 tires. How did those bushings look on your old struts?
There should be somebody kicking around the forums who can check the part numbers or at least give you a ride height measurement.
tag1260
Oct 31, 2018 06:56 AM
bimmadave
Jul 4, 2017 04:05 PM
therealratfink
May 20, 2013 06:44 PM
deraj
Suspension
Nov 21, 2012 03:39 PM
duc907
Feb 9, 2012 04:21 PM
