Suspension R52 Front End Sway Bar Links Question
Old Apr 1, 2020 | 06:56 PM
Sean Medley's Avatar
Sean Medley
I purchased some coil overs from ECS and am planning on setting them to drop the front by 1”. Looking at links blew my mind though. I saw that M7 has 8 choices for their Maxx brand, with lengths ranging from 150mm to 350mm. Would someone help me understand the variation, and which I’d likely need for the 1” drop? I think I need the 300-325mm for the 1”, maxed out, or the 325-350mm to get from 1”+, but I defer to those with greater knowledge.
Old Apr 2, 2020 | 06:16 AM
Hello,
Thanks for the purchase. Some coilovers include the links it needed. The stock endlinks you can measure and take 1" then convert to mm, i am not at work and remote otherwise I would jump back and measure for you.
Old Apr 2, 2020 | 01:14 PM
Sean Medley
Thanks for the quick reply and assist, ECS. My name has been flying through your ordering system since November, and it looks to be happening again with this!
Old Apr 2, 2020 | 01:37 PM
veedubpat's Avatar
veedubpat
Yeah honestly that's crazy, and I'd just buy the Turner (owned by ECS now) or Whiteline (I've used them on a bunch of my cars with success) for ~$125 or whatever it is and call it a day. That might be the rear price though, as I've been spec'ing that stuff out all day for a rebuild.
Old Apr 2, 2020 | 01:53 PM
Sean Medley
Thanks for the feedback on the options!
Old Apr 2, 2020 | 06:26 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Honestly most coilovers will work with stock end links unless you slam the car as the attachment points on the coilovers should be the same position. On coilover sets that they move it they usually include links.
Otherwise check out our WMW end links as they adj shorter than stock. Plus they have sealed ball sockets so they won't make noise or fail quickly.
https://www.waymotorworks.com/wmw-ad...-endlinks.html
Subw00er
May 31, 2018 06:47 AM
RudeJoe
Suspension
Jun 2, 2017 09:11 AM
Chiro444
Mar 29, 2017 08:58 PM
ClayTaylorNC
Jan 26, 2016 01:15 PM
qwertmonkey
Suspension
Jan 14, 2007 09:55 AM
