Suspension Coilover Conundrum
Old Dec 28, 2018 | 09:48 AM
BlackMarket's Avatar
BlackMarket
Smile Coilover Conundrum
I have recently Installed the following mods to my '15 MCS(A):
- NM Alpha Springs
- NM End Links
- NM Rear Sway Bar
The ride is DEFINITELY stiffer than I expected (other car is e300, is this to be expected compared to my other car?). I was wondering if I add coil-overs will it improve the ride quality at all? I've been told coilovers will make the ride more stiff, race car like. Is this true? If not, please provide Recommendations on quality coiliovers! I drive like a bat out of hell, I'm in the process of getting the engine built so I can turn up the boost. This is for context on how I want the car to perform. Don't know if I'll ever track the car but may on occasion with my friends.
Thanks in advance
BlackMarket
Attached Thumbnails Coilover Conundrum-img_1792.jpg   Coilover Conundrum-img_1793.jpg
Old Dec 28, 2018 | 09:56 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Most people would do coil overs or springs, not both. The coil over has the springs with the added benefit of adjustments and different dampening rates. You did two things coils and sway that will stiffen ride. Try removing bar or coils and see what that does for you.
Old Dec 30, 2018 | 05:29 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Springs need to be stiffer when lowering, because you have less suspension travel. Do you do anything to the bump stops, like trim them down? You ‘could’ be riding in the bump stops at your lowered height, which would cause the suspension to be stiffer than from the springs alone...
Old Jan 6, 2019 | 04:16 PM
TVPostSound's Avatar
TVPostSound
- NM Alpha Springs
- NM End Links
- NM Rear Sway Bar
Thanks in advance
BlackMarket
NM are relatively soft.
NM however requires the Micro Cellular Jounce Bumpers to be trimmed. (Others call them bump stops)
Grotah
R55 :: Clubman Talk (2008+)
24
Aug 28, 2008 06:29 PM
RVExotics
Jan 11, 2008 01:17 PM
RedSkunk
Suspension
15
Jan 22, 2007 04:01 PM
countrym
Tires, Wheels, & Brakes
19
Jun 24, 2005 12:07 PM
Innes
11
Oct 28, 2002 03:03 PM
