Suspension Mid install HELP! - megans on r52 - possible to drill rear for adjustment screw?
Old Apr 28, 2018 | 12:02 PM
Subw00er's Avatar
Subw00er
It looks like its going to hit some stuff for the top mechanism - lots of stuff around there, and its not as clear as the r53 setup. Has anyone drilled holes for rear adjusters on a r52 convertible?
Old May 10, 2018 | 09:11 AM
downshift1's Avatar
downshift1
I have holes drilled for my rear adjusters.
Take the rear top hats off and mark the inside of the chassis for where to drill.
There is a wiring loom directly over the top of the rear strut on the inside of the car so make sure you move that first.
Old May 10, 2018 | 05:17 PM
Subw00er's Avatar
Subw00er
I ended up figuring it out. here are a couple pics that may help someone else out. I dont have pics of the adjusters themselves at the rear, but I was able to get them to come out the sides of the trunk carpet, just behind the rear seats. They stick out about .5"
If you pop out the rear seat (just pulls up at front and out) and look towards the outer seat belt anchors, this is where the hole ends up. There is indeed wiring looms on both sides. I had a friend hold a piece of metal above where I was drilling to make sure I didnt hit them. You can kind of pull them aside as well. I used a step bit and it made a nice hole. Make sure the hole is a little bigger than you think because the shock will pivot a bit when its going over bumps. Also, you can remove the top adjuster **** so you only have to drill a 1/4" hole in the carpet to get it out - looks really clean.
This is the max ride height for the megan coilovers. The rear sits higher than I thought it would - it may even be higher than stock?! It needs to go down >1" to match the front drop. The install directions called for 80mm of threads to be screwed in when adjusting the height at the front, and 30mm in the rear, so its got plenty of adjustment to go down.
Old May 17, 2018 | 08:12 AM
Thinker2112's Avatar
Thinker2112
Did you pull the interior panels out?
Old May 17, 2018 | 07:37 PM
Subw00er's Avatar
Subw00er
There was no need to do so. Just the seat
Scooter24
Sep 27, 2016 03:45 AM
jcwmc40
Mar 28, 2014 05:00 PM
MINIopoly
Suspension
23
Jul 8, 2012 05:49 PM
taumax
28
May 10, 2012 11:16 AM
kevinminict
Oct 16, 2007 05:37 PM
