Suspension Coilovers and 18's
Old Jan 12, 2018 | 01:31 PM
boosted10's Avatar
boosted10
Coilovers and 18's
Hello all ... New to the lowered mini world ... I just picked up a 2010 cluman s laural ed and looking to do some upgrades. I have somewhat of a budget since im doing motor upgrades ans suspension at the same time.
Here is my question .... Do i need a spacer to run a 18x8 +38 when lowering the car on raceland or godspeed coilovers ? 215-40-18 tire size ....if i dont go with coilovers the h&r 1.4" springs and factory struts are my 2nd option.
Thanks in advance.....
Old Jan 13, 2018 | 08:55 AM
cornjuice's Avatar
cornjuice
likely spacer in the rear for sure.. if you have JCW brakes up front, possible small spacer as well
at least a 5mm rear spacer.. if not 5mm front/10mm rear
*front calipers and rear strut are the clearance issues
Old Jan 13, 2018 | 10:43 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
18x8 +38 shouldn’t need spacers, but will require some camber to clear fenders.
This is a helpful website for checking clearance and fitment:
https://www.wheel-size.com/calc/
Old Jan 13, 2018 | 11:43 AM
Alpha Motoring's Avatar
Alpha Motoring
You won't need to run super aggressive camber up front to clear, I would run 215/35/18 though with that setup to get some stretch. Rears will rub for sure if you do not run aggressive camber.
Old Jan 13, 2018 | 11:47 AM
boosted10's Avatar
boosted10
When you say aggressive chamber can you elaborate on how much ? I don't like the super staneced riding on 25% tire look. Im guessing the lower i go the more i will need. Has me leaning toward the h&R springs.
Ive dug through this site looking at over 75 pages of wheel pics and i think I'm more overwhelmed now then before.
Old Jan 13, 2018 | 11:50 AM
boosted10's Avatar
boosted10
This is my car ... any input on thoughts for wheels/ suspspension would be appreciated.
Attached Thumbnails Coilovers and 18's-743d0744-ce7a-4308-87b1-3a4a7a351bc5.jpeg
Old Jan 13, 2018 | 12:31 PM
Alpha Motoring
You will rub the rear fender liner/wheel arch with that width/offset/tire combo on a lowered R55/56.
A slightly lower profile will help reduce some of the rubbing and you'd want to run some camber to avoid further rubbing.
You should be ok with springs but definitely not with coilovers if you're planning to go low.
SD5
Suspension
37
Jan 23, 2009 07:41 PM
scolburn79
Suspension
102
Nov 7, 2008 01:42 PM
roofaS
Suspension
47
Mar 30, 2008 04:18 PM
CynMini
Suspension
Mar 16, 2008 09:17 AM
skuzy
Suspension
12
Apr 4, 2006 04:31 PM
