Suspension KW Coilovers: you need to know this...
Old Aug 5, 2008 | 10:55 PM
  #26
HighLife4136's Avatar
HighLife4136
Originally Posted by BiZzLeSMiNI
hey guys,
reviving an old thread... but i finally took the plunge and bought some coilovers. after reading reviews on here and asking around for quite some time, i finally bought the kw v1's. im sure they will give me the exact ride and stance im looking for but...should i be worried about this rubbing issue with these two sets of wheels
1. stock x-lites
2. flik wasps 17x7 et 42
please tell me ill be fine!!! or if i need spacers but... im hoping i will at least be fine wit the fliks w/o spacers for now as it is still the summer and these will be on
I've got the Wasps and they needed no other modifications
Old Aug 6, 2008 | 05:01 AM
  #27
BiZzLeSMiNI's Avatar
BiZzLeSMiNI
i wanna do spacers for the wasps anyway to bring them closer to the fender but what about the x-lites, will they cause rubbing even at the highest setting for the coilover? i will be running these in the winter so i dont care about the drop
Old Aug 7, 2008 | 02:14 AM
  #28
CooperSlad's Avatar
CooperSlad
So why do the KWs rub when other coilovers don't? Would my standard bullets rub?
Old Aug 8, 2008 | 02:04 PM
  #29
txwerks's Avatar
txwerks
It's not just "some" coilovers that can cause interference issues.
There are MANY things to consider - ride height (meaning where you set the lower perches), wheel offset and tire width must also be considered. Depending on where the lower spring perches end up, you may get rubbing on the tire or wheel as a function of the tire width and offset of your rims. And, in some cases, no matter where you set your ride height, the offset or tire width may be an issue! Also, if you're running a BBK, the hat may or may not be as thick (or even thicker as with our BDM BBK) as the stock rotor. All of these factors have to be considered.
We just installed a set of AST's on a customer car running some generic 16x7 wheels with a +40 offset and 205/50R16 tires. We could get our index finger between the spring perch and the tire, so that obviously wasn't an issue. However, this customer also had two sets of track wheels - one with a +42 offset and the other with a +40. We advised him to pick up a set of 3mm spacers for the +42 wheels, else he may find himself SOL if he showed up for a track day expecting those wheels/tires to clear everything.
Old Aug 9, 2008 | 02:45 AM
  #30
howsoonisnow1985's Avatar
howsoonisnow1985
GP Lift points
Hey do you guys have the lift points for the GP yet?
Rohdeandschwarz
May 16, 2019 08:59 AM
lifeofjenn
19
Sep 24, 2015 11:01 AM
3L6
Sep 21, 2015 06:21 PM
Phantogram
Aug 12, 2015 12:11 PM
LostBoyScout
Dec 11, 2003 11:12 AM
