Suspension BC Racing for F56 BR Type RA with camber plates
Old Apr 11, 2018 | 12:28 AM
  #26
8Balls's Avatar
8Balls
Hi Gardus, this is my 1st post on the forum after finding your BC coilover install
I have a couple of questions the 1st being : Could you tell me how you went about coding the DDC as I would like to do this as the KW DDC delete kit here in the UK costs over £350?
2nd question : You say you have supplied does this mean you have this set available? I have contacted a few dealers here in UK but cannot get the exact kit
Cheers for any info
Old Apr 11, 2018 | 08:51 AM
  #27
vetsvette's Avatar
vetsvette
Moderator
I'm not Gardus, but I did recently install the same coil overs on my F56 to replace my OEM Sport Suspension W/NM springs.
If you install coil overs, regardless of the brand, you will lose the DDC function. The kits listed as comparable with DDC just include a plug in to spoof the car into thinking everything is fine with the DDC system. Doesn't cause a problem, but is a waste of an expensive OEM option.
No idea on your second question. You might try to contact Gardus via PM though.
Old Apr 11, 2018 | 09:09 AM
  #28
8Balls's Avatar
8Balls
Hey vvetsvette thanks for the reply, I picked up the F56 used so the loss of the VDC is no problem
Not worried about losing the function really, I was thinking about springs but I don't want to stress the OEM's and also could not get as low as I wanted.
Cheers
Old May 16, 2019 | 08:04 AM
  #29
Darbys2019MiniJCW's Avatar
Darbys2019MiniJCW
Will their camber plates work with a Bilstein B14 PSS? I installed them but need camber plates for my 2019 Mini Cooper S JCW F56. I got the NM Rear Control Arms but not any Camber Plates for the front!!!
Old May 16, 2019 | 10:13 AM
  #30
vetsvette's Avatar
vetsvette
Moderator
To my knowledge, the only way to get the BC camber plates is as part of the front strut assembly.
Old May 16, 2019 | 03:28 PM
  #31
Gardus's Avatar
Gardus
You can use the Silver Project camber plates, they are made to work with the stock suspensions or any suspension kit compatible with the OEM top mounts.
I fitted and sold quite a few and they're ok.
https://silverproject.eu/product/cam...i-f55-f56-f57/
Pay attention to not get the ones for coilovers, as those are for suspension with a independent upper spring perch and won't work with the B14 PSS.
If you have trouble getting them in your country let me know.
Old May 16, 2019 | 04:01 PM
  #32
Darbys2019MiniJCW
What would be the cost in US Currency including shipping to New Braunfels, Texas 78130?
Old May 17, 2019 | 06:49 AM
  #33
hadjiikong's Avatar
hadjiikong
If you are in Texas I would look at Vorshlag. They make them for our cars and sell them to WMW.
Link to WMW
Old May 17, 2019 | 11:51 PM
  #34
Gardus's Avatar
Gardus
€ 140 (tax excluded) + shipping to the US € 30 with DHL Express.
Old May 18, 2019 | 04:05 AM
  #35
Darbys2019MiniJCW
Link to WMW
Contacted them twice...they say they are weeks out with no exact date...
Old May 19, 2019 | 12:28 PM
  #36
strat61caster's Avatar
strat61caster
There's also K-mac which I just saw in another thread:
https://www.northamericanmotoring.co...ml#post4446361
After not checking in for awhile it's awesome that there's finally camber plate options, Vorshlag finally stepped up, Silver, K-Mac, much better than a few years ago when your options were buying a 'clubsport' coilover and BC's were still on the horizon.
