F55/F56 Gollum IV - Power corrupts
Old Nov 27, 2018 | 04:27 PM
  #226
cmt52663's Avatar
cmt52663
Dyno Chart - Digitized
Pull the data from the chart - we need torque for a thrust chart
Old Nov 27, 2018 | 04:35 PM
  #227
cmt52663's Avatar
cmt52663
The Thrust Chart
So, by applying the gear ratios (end to end) simple multiplication turns torque at the flywheel into torque at the axle, and due to the 24" diameter of the wheels that means each foot/pound of torque at the axle equals one pound of lateral thrust at the contact patch.
Gear Ratios, including Final Drive
Which yields this Thrust Chart!
Note real world thrust is limited by traction...
This interests me for a few reasons:
1. the car is traction limited on the bottom two gears on anything but the stickiest road
2. as usual, max thrust is achieved by using all RPM before selecting the next gear
3. throttle induced wheelspin is not only possible, but also frequent in the bottom two gears - feather or spin!
4. adding even more power underscores the underlying predicament that on acceleration weight transfer is the enemy!
Cheers,
Charlie
Old Nov 27, 2018 | 07:49 PM
  #228
Eddie07S's Avatar
Eddie07S
Say What!
or is that:
Say WOT!
Old Nov 28, 2018 | 03:26 AM
  #229
cmt52663's Avatar
cmt52663
Thrust chart in G
Acceleration values over .5 G are unlikely in the real world, at least in my experience. Hoosiers or drag slicks with 9" + wheels can do it, but it is not easy! This again underscores the point of diminishing return for engine power...
That's a stump puller of a 1st gear...
Cheers,
Charlie
Old Dec 11, 2018 | 04:27 AM
  #230
cmt52663's Avatar
cmt52663
2019 improvements - sticking it to the road
This Friday Santa (via FedEx) should show up with next year's rolling stock. Knocks off seven pounds per corner and will allow a 225 to really work...
Neuspeed RSe05 black -- 88.05.03B
  • Size: 17x8.0
  • Offset (E.T.): +45mm
  • PCD (Bolt Pattern): 5-112
  • Center Bore: 57.1mm
  • Weight: 17 lbs.
TPMS, related wheel hardware mount & balance
Supreme Power machining of center bore from 57.1mm to 66.6mm
Bridgestone RE 71R 225/45-17
The total butcher's bill is $2,780, which ain't hay!
Thanks to NM Engineering, Supreme Power, and Bridgestone for helping stick this little hot rod to the road next Spring.
I'll still get pummeled in STX next year, but will have plenty of fun.
Cheers,
Charlie
Old Dec 11, 2018 | 06:26 AM
  #231
Eddie07S's Avatar
Eddie07S
Pictures?
On my S a 10# reduction in weight per wheel is really noticeable in acceleration. There is also a slight improvement in ride from the reduced unstrung weight. You are really going to love them.
Old Dec 15, 2018 | 12:03 PM
  #232
cmt52663's Avatar
cmt52663
But do they fit?
They do look nice...
2019 footwear...
Cheers,
Charlie
Old Dec 15, 2018 | 01:49 PM
  #233
vetsvette's Avatar
vetsvette
Moderator
I have the same in 17X7.5 and love them.
Old Dec 21, 2018 | 01:31 PM
  #234
cmt52663's Avatar
cmt52663
OK, better sneakers in 2019 - see also this post. That should help manage the power.
Cheers,
Charlie
Old Dec 31, 2018 | 05:27 PM
  #235
cmt52663's Avatar
cmt52663
Driver's course....
It is winter. Days are short, and temperatures are cold. Oh woe.
What to do?
Well, if you are (as I am) a borderline geriatric child motor head frustrated wannabe, then you spend the winter in a driver's course so as to prepare for spring time.
What course is that d'ye say?
Why the on-line tutorial recently published by fellow SCCA member (and National Champion) Vivek Goel.
Who has published a focused, relevant, well footnoted, and unique set of materials aimed exclusively at autocross.
These materials are based on Vivek's first hand experience, but the bibliography has also been a tremendous resource.
The Perfect Corner The Perfect Corner
(Paradigm Shift), for example - or (and I think this was a crossed wire but still wonderful)
The Lost Art of High Performance Driving The Lost Art of High Performance Driving
(Ross Bentley)
At present, and I've ground yet to travel I am trying to ingest and internalize two key points - one from each of these two tomes:
  • From The Lost Art - drive collaboratively (which focuses on my street driving which features short following distances and quick decisions - not pretty), and
  • From the Perfect Corner - consider the Euler Spiral! Believe it or not Pierro Taruffi has this (at least on exit) in the "Technique of Motor Racing" 1958 but I had missed it completely!
And to practice?
Well, I am one of the last OG hold-outs for the "Grand Prix Legends" and hone my skills (read, make thousands of mistakes) in that domain. Specifically I practice with a 1967 Ferrari F1 car on the Nurburgring, which is a merry challenge.
Look ahead? Yup that applied big time.
Be smooth? Yup, that too...
Feel the weight shift? Oh hell yes!
See the spirals? Actually, yeah - I am starting to connect it all.
Anyway, Vivek Goel is the first top rank auto-crosser to write anything down that I could grab a hold of, and I am most grateful.
Happ New Year y'all.
Cheers,
Charlie
Old Dec 31, 2018 | 05:48 PM
  #236
cmt52663's Avatar
cmt52663
What to do?
The Perfect Corner (Paradigm Shift), for example - or (and I think this was a crossed wire but still wonderful)
The Lost Art of High Performance Driving (Ross Bentley)
And to practice?
Cheers,
Charlie
PS: I have a spreadsheet which records the approximate time of cataclysm and root cause (usually not looking ahead) for my myriad deaths on the Nurburgring... There should be 50 rows, but I am lazy. I can do a 9 minute timed lap now (necessarily preceded by a warm up also 8 minutes), but only one before my concentration wavers in some fatal manner!
PPS; A good simulator with wheel and pedals is even less painful than autocross (at least in the winter time).
PPPS: An autocross is usually 70 seconds or less, so.......
Old Jan 3, 2019 | 08:00 AM
  #237
Eddie07S's Avatar
Eddie07S
So, Charlie, finally gotten out "on the track".
A lot safer than what you can see on YouTube, at that...
Happy New Year!
Old Jan 3, 2019 | 02:57 PM
  #238
cmt52663's Avatar
cmt52663
Happy New Year!
Lol, Happy New Year.
Cheers,
Charlie
Old Jan 22, 2019 | 09:10 AM
  #239
cmt52663's Avatar
cmt52663
So winter has arrived with sharp teeth, an my hibernation continues.
My dear landlord allowed me to hide in the garage for a couple of particularly nasty evenings, and the tires work pretty well around zero...
The driver's course continues, now encompassing a half dozen good books and about 60 Nurburgring laps in that immortal 312. I'm finally able to do three laps without some hysterical (and usually fatal) mistake at high speed. I claim I've learned the course, which just leaves the challenge of driving it quickly and consistently. My lap times are now in the 8:42 to 8:50 range, which is close to my all time best performances of 8:39 (race) and 8:41 (qualifying).
And the winter parts disease has set in, as I confess I just ordered up some camber plates for next year.
I reckon those nice 225s on the 8" rims will just love about -1.7 front, and -1.8 rear. I'm not tempted by coil-overs this time, as the sport springs and B8*s taken with the NM bar are quite capable, and I like the ride height just fine.
We shall see.
Cheers,
Charlie
Old Jan 23, 2019 | 12:21 PM
  #240
cmt52663's Avatar
cmt52663
Hard to get a body roll number, but that's kinda fundamental when considering optimum static camber in a McPherson Strut front end.
I found an On-Screen Protractor (love SourceForge) that acts as a "top layer" when reviewing photographs, and then pulled out 129 Slayer's best photograph of Gollum IV turning in at 9 tenths.
Lean and mean...
From this analysis I do reckon that the max positive camber change on the outer edge of the car will be in the 2.5 to 3.0 degree range.
So it's a straight up (pun intended) trade off between best cornering (more camber) and best braking and acceleration (less camber).
Cheers,
Charlie
Old Jan 23, 2019 | 02:38 PM
  #241
Eddie07S's Avatar
Eddie07S
Charlie,
Years ago Grass Roots did a one car (R53 race car, on a track) test of camber and worked their way up to -3.5 deg. If I remember correctly, anything above -3.0 was a looser in lap times because of the loss of braking capability, even though they were seeing higher cornering g’s. From their one car test, they concluded that -3.0 (maybe it was slightly above that) was the most someone would want to use. Of course, you could lower that number by adding some caster to the suspension. But I don’t know how to do that on a F series MINI.
I know the Grass Roots article is still on line, but I don’t have a link (sorry). It is an interesting read.
Old Jan 24, 2019 | 04:22 AM
  #242
cmt52663's Avatar
cmt52663
Charlie,
I wonder what their roll angle was with that car?
Thanks for the tip Eddie.
Cheers,
Charlie
Old Jan 24, 2019 | 05:44 AM
  #243
Eddie07S's Avatar
Eddie07S
I haven’t seen anyone talk about roll angel in ages (including that Grass Roots article). Back in the day... Road and Track would publish pictures of the cars they were testing with the roll angle marked on them. I’m not sure anyone knew what to do with that information, though, and they stopped doing it.
As for your analysis, remember that the suspension compression is adding a little bit of negative camber. It may not make a lot of difference, other than having you be more comfortable with a setting of -2.5 deg and not thinking you should go higher. I have friends who used -2.5 on their street cars for running on the track and liked it. They felt the added tire wear on the street was minimal.
Old Jan 24, 2019 | 05:54 AM
  #244
cyow5's Avatar
cyow5
That's because you are omitting weight transfer, the bane of FWD. The faster a FWD accelerates, the more weight transfers to the rear. That's also why you see hypercars like the McLarens keeping up with AWD ones now - the acceleration is so high that the front wheels are hardly contributing.
I have an Excel sheet that pulls in CG and wheelbase to estimate rear weight transfer, and a FWD with reasonable tires will really struggle to get below 5s 0-60. Also, an easier way to calculate contact patch thrust is from power, not torque - F=P/V. Just calculate what rpm you are at for a given velocity, and then you can get the force. Just be careful with units and the divide-by-zero.
Old Jan 25, 2019 | 03:27 AM
  #245
cmt52663's Avatar
cmt52663
Now to see what my crew chief thinks of this lot.
(Joel DeCoff - Chief Mechanic at Mini Of Peabody)
Should be fun - looks like good quality kit on first impressions...
Cheers,
Charlie
Old Jan 25, 2019 | 05:10 PM
  #246
Eddie07S's Avatar
Eddie07S
OMG!!!!!
Beautiful!
Old Jan 25, 2019 | 05:33 PM
  #247
cmt52663's Avatar
cmt52663
Well that lot goes in Monday, and I'll also reinstate the NM rear bar (exculpated during the rattle hunt)..
So that'll give me a perfect dry weather chassis, just in time for February.
Gotta be some madness in my methods.
(Joel liked the hardware by the way).
Gee, if I kept the winter tires and put in the 17x8 rims and dialed up max camber I could be poked and stretched!
(Didn't say that)
Cheers,
Charlie
Old Jan 30, 2019 | 03:37 PM
  #248
cmt52663's Avatar
cmt52663
And now, after a certain amount of fuss, here is Alignment 2.0.
(I think I'll enjoy STU rules - I've wanted to do this since September of 2017).
Thanks again and as always to Joel and Kevin at MoP, and in this case also to Tire Rack and NM Engineering.
-2.0 at all four corners....
Come March and the 8" rims with 225 RE-71 this should turn rather well I think - we shall see.
Cheers,
Charlie
Old Feb 19, 2019 | 06:44 PM
  #249
cmt52663's Avatar
cmt52663
After a spot of bother with the B8 Bilstein struts, they've now both been replaced.
No further creaks, rattles, or other drama - Gollum is now solid as a brick.
Thanks to the Pit Crew yet again - a bit of patience and a quality approach have yielded Alignment 2.1...
The waiting for the warmth that will allow the new wheels and tires is now a bit of a strain...
Cheers,
Charlie
Old Feb 19, 2019 | 06:52 PM
  #250
dpcompt's Avatar
dpcompt
What are your new shocks?
