Suspension F55 and H&R Springs - Review.. Alignment Experts GITT
#26
Why did he mess with the rear camber?
Barring having camber arms, I would have left them at -2 degrees on both sides.
You now have 1 degree of cross camber between the rears. Can get a little squirely.
Ive done a few thousand alignments in my first career. Seriously.
These will be my arms of choice when the time comes. Only $165 a pair.
http://www.meganracing.com/product.asp?prodid=2022
#28
#30
Also thanks for the info TV
#31
So this may be a stupid question;
I will be installing the rear control arms myself. Always do all of the work myself. Since toe is spot on is there a way for me to set the camber myself at home instead of going to have another alignment or is that foolish and just let the alignment guys do it correctly.
Will adjusting rear camber with adjustable control arms throw off toe?
#32
On an alignment machine, its easier to see the cause and affect, by going back and forth.
You're going to bring the camber in and toe will go out, as in the original measurements.
#33
#34
Damn you making me spend more money! lol
#36
#37
#38
They forgot to do mine, also, might not pertain to you, the tech had to reinitialize the EPS (Electronic Power Steering) to keep the car from pulling under 30 mph.
My springs are sitting in the garage, been working too much.
#39
Eibach Kit Installed
Measurements from bottom of center cap to bottom of fender
Front Before
387.35 mm
Front After
358.775 mm
Lowered 28.575 mm or 1.125 Inch
Rear Before
371.475
After
346.075
Lowered 25.4 mm or 1.0 Inch
Will Measure Again in 1000 km's
Front Before
387.35 mm
Front After
358.775 mm
Rear Before
371.475
After
346.075
#40
#41
Sorry to bump an old thread...
I have a shop and a 19 MCS F55. I had a client recently come in for a sprint install on a 16 F55 JCW. Simple job but the vibration under acceleration issue crept up. The issue is a geometry change on the CV half shafts. The inners on our cars are very stubby and don't allow for much "free play" even from the factory. When you lower the car that free play is taken up by the change. Honda S2000s suffered from this and require a spacer between the axle flange and axle shaft..
Why do you ask if Porsches etc don't have this issue? Porsche's are my specialty BTW. They simply have completely different suspension setups with a lot more factory adjustability built in.. however if you really lower let's say a 996 C4S the front axles will get destroyed.. similar to what I mentioned that "free play" gets taken up. Even the rear factory toe/camber arms will only allow so much adjustment range when lowered. In short their setups are already "optimized" for low ride height and the possibility of going a bit lower..
As for different part numbers in the EU. That comes down for the Tüv certification process which is required for road worthiness.
Feel free to ask me any questions..
PS bump stops should always be trimmed before lowering springs install. I use let's say a 30mm drop I'll trim 20mm off the stop
J_L (06-12-2019)
#42
RESPONSE: Its the wear pattern made in the inner CV bucket, prior to lowering, the joint after lowering no longer rides in that wear pattern, and wants to tramline back into the groove. This the spacer in the S2000. to bring it back to its original position within the inner bucket.
RESPONSE: I have and still in communication with H&R in Germany regarding a bushing issue I have with my rear sway bar.
Have had many conversations on their philosophy, as they are OEM to many European auto brands.
They make spring specs based on the cars weight. Thus a different spring for the F55, than the F56.
The US distributor does not sell a spring for the F55.
[size=3].[/size]
RESPONSE: Bump stops (BTW wrong name) should only be trimmed based on the spring manufacturers recommendation.
As they are technically now, a suspension component. Not as in the past.
Read this:
http://www.hrsprings.com/technical/m...-jounce-bumper
[size=3].[/size]
Read this:
#43
I will note that I seem to remember reading that people had replaced CV joints and still had the vibration problem and that people with older cars didn’t have a vibration problem with vibration when lowered??? And I seem to remembered that there was discussion about not being able to go beyond an inch to an inch and a half with the MINIs. Not sure I can find those past threads and I am going by memory here and could be mistaken. But recollection is that it seem like no one knew for sure what the caused the lowering vibration or what the fix was.
I’m interested as I am looking at lowering my new JCW and don’t want problems.
#44
I have read this before about the wear pattern. So that would say that the vibration would not occur with new CV joints. Any idea of how long a new car can go before this becomes a problem when lowered?
I did mine at 6K, had a small vibration, now at 12K I cant feel it, as it created a new wear pattern.
Car Care Products
03-17-2016 03:35 PM
