Suspension Best Adjustable Swaybar Endlinks
I had the Webb ones first, and although they were light and strong,
but they eventually seized, probably because the design is open to the
elements at the ball ends, so went to a covered joint model the next
time around. They are solid, sturdy, and quiet.
http://www.detroittuned.com/detroit-...able-end-links
http://www.waymotorworks.com/wmw-adj...-endlinks.html
We've been using ours for years and they are not only quiet, but reliable as I even use them on my race car
I just put in Detroit Tuned's endlinks. I ordered and got them in the car within the same week. Pretty quick shipping.
Although you purchased a set already, I'll just throw Whiteline out there for other options. I run all Whiteline suspension components on my car for the track and daily use. Nothing but complete satisfactory of their products.
Can check them out here - http://www.pelicanparts.com/catalog/..._pg1.htm#item3
888.280.7799 | 6am - 5pm PST
bumping this - my car 's rear clunks pretty bad over bumps, but other than that it's fine - this would more or less be for noise reduction - i can't do much for corner balancing in HS. worth the $155 for WMW's endlinks?
I'm leaning towards the WMW/Detroit Tuned end links, but saving me money has me considering Whiteline and Superpro, too. They all have the sealed boots which should keep them quiet for a long time. The lowest priced sealed adjustable end links I've read decent things about are the Donald the Bonald links on eBay. I think they're about $85.
happen to have the part number for whiteline? 4th of July is coming, i'll keep my eye out for deals from WMW or others
I have the WMW links.
They are very quiet and well made.
If they are loose at all, you will know it. Most of the noise comes from not being installed properly or loose bolts or jam nuts.
Alpha Motoring
Apr 10, 2016 08:27 AM
