Suspension Suspension: Stock vs. FSD vs. B4 ??
I tried to do everything all at once-
Struts
Ireland Engineering fixed camber top hats
Power flex LCA's
Power flex f&r sway bar bushings
Inner & outer ball joints
Rear strut top donuts
Struts
Power flex LCA's
I put a set of FSD's on my mini when it had around 100,000 miles on it. HUGE different in ride quality and handling. The stock springs should be fine....no reason at all to swap them out.
If I had to do it all over again, I would still pick the FSD's. The ride is very firm and controlled, but not harsh like I've heard the KONI Sports can be.
I have around 140,000 miles on my mini now...and the FSD's still ride very nice.
Anytime!
Thank you for your order and if you need anything please let me know.
888.280.7799 | 6am - 5pm PST
This list is pulled from our suspension overhaul kit:
New Front Strut Mounts - here
New Rear Shock Mounts - here
New Bump Stops (where applicable) - here
New Rear Shock Boots (where applicable) - here
New Strut/Shock Mounting Nuts/Bolts - here x2, here x6, here x2, here x4
New Front and Rear Spring Retaining Pads - here
Let me know if you have any questions.
Stick with OEM Supplier or Genuine on the mounts (front and rear). The OEM Supplier Lemforder strut/shock mounts are very well priced and are a sufficient replacement. For the bump stops Genuine. For the spring pads I'd just stick with Genuine since the pricing points compared to the aftermarket ones are not that much of a difference.
I would try the Powerflex bushings for the rear shock mounts .Rebuilt my rear suspension last year with new OEM parts all around except for Koni FSD shocks...
The OEM foam bushings failed within three months, bought another set ( both Lemfoerder) and they failed also, within months.I think they need to use a higher durometer foam.I'm going to the Powerflex even though I am sure they will transmit a bit more noise.
They just crush and don't rebound, leading to clunking at the tops of the shocks which is very irritating not to mention tough on the shocks which are not cheap.
And remember to get new bolts for your strut mount plates.Save yourself some trouble and annoyance.
The rear shock mount bushing kit, but yes you could go with the Powerflex bushing set HERE as a great performance alternative. Not only do Powerflex bushings give you better handling and performance, they're also more cost-effective than OEM bushings. Our full suspension kits include both the upper and lower spring pads for the front and rear suspension. You may not need them and can inspect yours to see the condition that they're in. We include them in the kit because you'll be in there for that job so you might as well replace/refresh all that you can while everything is apart.
Anytime, Steffen. Glad I could help. If you have any other questions just let me know.
I'm jumping on the bandwagon here. We have an '04 that is feeling like it could use some ride help. Thanks for the list of parts that are needed.
A slightly off topic question - I have a set of the Bilstien sport shocks I bought used for my 2012 S and the blue corregated dirt/dust shields are damaged on both front shocks. Does anyone know where to get replacements? Thanks for any help with this.
I suppose that is understandable as there is probably almost no call for them. I had thought about trying the stock ones but I think you may be right about the stock ones being smaller. You gave me another thought which is to put a WTB in the market place. In the NE here I have to believe I am better off having them installed than not; the salt kills anything not covered.
Thanks for checking.
Yes, correct.
I have not yet decided. I had a set of the FSDs on my '07S and really liked them. Now, with 55K on our '04, I had thought to put the FSDs on that car too. But with what people are saying about the B4s and the cost difference I am giving them a hard look. I need to do the exhaust first. Once it warms up and I get that done, then I'll decide.
