Suspension Wheel Spacers
Old Dec 6, 2014 | 07:44 PM
MidnightF56's Avatar
MidnightF56
My f56 has the factory cosmos 17x7 wheels. I'm looking to give the car a slightly wider look, and was thinking that wheel spacers were the way to go for right now.
As far as I can tell, I basically have two options: the 5mm range or 12mm range.
My questions are as follows:
1) With 5mm spacers, there is no hubcentric mounting collar on the spacers, because the spacer is thinner than the collar on the hub. Does the remaining 5mm or so of collar on the hub allow for the safe mounting of the wheel? And what length bolts do I need to buy?
2) If I go with 12mm spacers, the spacers have a collar that replaces the one on the hub, so the wheel can mount safely - no issues there. But will I have rubbing against the fenders with the stock wheel/tire setup? I'm not planning on lowering the car.
Thanks for your help! I'm not super savvy when it comes to these kind of mods.
Old Dec 7, 2014 | 08:31 AM
randomquickness's Avatar
randomquickness
I'm pretty sure you can do the 12mm without rubbing if you're keeping the original tires and not lowering it. Should give it a shot, I'd like to see the results as I'm sure some others would.
Old Dec 7, 2014 | 12:21 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
If your not lowering the car I think you can do up to 15mm without rubbing but it will depend on wheel and tire option.
Yes the 5mm spacer will have enough hub sticking out that it is perfectly safe to use.
We have our own 5mm and 15mm F56 spacers if your looking for a good quality spacer that doesn't break the bank.
Old Dec 7, 2014 | 05:35 PM
MidnightF56
Thanks, gents. I will buy and fit some at some point during the holidays, and share my findings with you.
Old Dec 7, 2014 | 05:37 PM
MidnightF56
Originally Posted by WayMotorWorks
If your not lowering the car I think you can do up to 15mm without rubbing but it will depend on wheel and tire option. Yes the 5mm spacer will have enough hub sticking out that it is perfectly safe to use. We have our own 5mm and 15mm F56 spacers if your looking for a good quality spacer that doesn't break the bank.
Any chance you guys can get some 12mm ones made?
Old Dec 7, 2014 | 07:41 PM
j5ktt's Avatar
j5ktt
See my previous post for details of the spacers I fitted (12mm at front and 15mm at rear)
https://www.northamericanmotoring.co...storia-ny.html
Old Dec 7, 2014 | 08:58 PM
WayMotorWorks
Vendor
We're not planning on 12mm as 15mm will take car of most. That's what we have offered for years.
Old Dec 7, 2014 | 10:51 PM
MidnightF56
Originally Posted by j5ktt
See my previous post for details of the spacers I fitted (12mm at front and 15mm at rear) https://www.northamericanmotoring.co...storia-ny.html
Sweet! Thanks for sharing! She looks great...
Old Dec 8, 2014 | 06:54 PM
SemperMini's Avatar
SemperMini
Anyone have thoughts on how much you would think of adding in spacer width for a slightly lowered (~1 inch) MCS if I wanted to get a little better cornering performance without risking tire rub?
Old Dec 14, 2014 | 02:04 PM
MidnightF56
Semper, I've been told 15mm max on the stock wheels, which sounds accurate given the amount of people running aftermarket 8" wide wheels.
I'm going with 12mm on all four wheels, just to play it safe. I think there's room in there for a 1" drop with stock wheels, but you'd probably be better off if your suspension is adjustable and you're willing to mess around with it.
Kimolaoha
Jul 5, 2023 01:04 PM
DixonL2
Apr 13, 2021 08:05 AM
khumpert
Nov 30, 2015 11:48 AM
Rennfahrer555
Aug 13, 2015 09:07 AM
ti22fjc
Aug 9, 2015 05:49 PM
