Suspension Rear camber is out of spec range..... options ??
I did a quick search but didn't find what I was looking for. My rear camber is out of the spec range and I would like to fix it.
What are the options for fixing the rear camber on our second generation cars?
Also, what options on the front end ?
Rear adjustable control arms to adjust camber in the rear. Use them to replace the lower control arm. Lots of options out there. I like the H-sport arms.
For the front you'll have to get camber plates to adjust camber. The easy button is the Ireland Engineering non-adjustable camber plates...
http://www.waymotorworks.com/ireland...5-r56-r57.html
The better question is why is your rear camber out of spec?
Yes the best way to correct the rear camber is a set of Hsport Rear Camber links.
They will give you the adjustment you need to reduce the rear camber and get your alignment correct.
Thanks for the info. Appreciated. I guess it's time to spend a little more cash. So just to be clear. I have too much camber. These will allow me to dial that camber back in, correct?
Car is out of spec due to lowering. Back end is out by more than a degree from the acceptable tolerances. Front end out by less than 1/2 a degree from acceptable tolerances. Back end definitely needs attention as its causing increased inside tire wear. And as I just put on new rubbers, figure it's a good time to clean up the specs.
Yep the camber arms allow you to move the camber back towards zero. So go from -2 to -1 for example.
What is your front camber at? If it's -1 or somewhere around there I wouldn't mess with it.
I ran the Hotchkis links for over 90k miles in New England with no problems. My setup was also lowered, and I returned rear camber to -1 degree to balance the chassis for autocross use.
I've not done business with Way myself but as an old troll I can testify that their reputation in this crowd seems to be very good. Who posts for Way by the way? I haven't been introduced.
Their HSport link is the same product as my Hotchkis link, so my point is "Amen"...
Cheers,
Charlie
Cheers,
Charlie
Minibeagle
Aug 13, 2015 10:00 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
