Suspension How loud are my TSW spec KWv2's supposed to be?
knocking over bumps is normally due to the drop links no longer being the correct length due to lowering, especially at the rear the drop links/arb make contact with the spring/shock.
If you are running the stock drop links your front and rear ARB will now be pre-loaded, if you have the funds source some adjustable drop links, I run powergrid ones and they are fine, they can allow you to return the ARBs to a neutral position.
Yes, very similar. Like yours, I do not really see any threads showing above the nut.
I am usually not one to bring back to life really old threads...but it came up in my search...
Mindspin311...you are local, and near me...what did you end up figuring out with your install? Did you ever find the source of the clunk. I have a similar clunk, but am running KWv1 and IE camber plates...trying to figure out if it is the plates making all the clunk or if it is the endlinks?
Havent solved it yet. But, I am pretty sure it's the camber plates.
I took the car to Harrison Motorsports for an oil change and asked them to check the suspension to make sure something wasnt loose. They claimed everything was nice and tight.
So, putting blind faith in them, I have to guess that its the main spherical bearing in the Vorshlags. I may bring the car to Way and have him take a look at it.
I am very curious to hear what you find...I figured that my crappy IE plates were the cause...and was going to get the Vorshlags...but if they are going to do it too...I have taken mine apart 4 times and put it all back together only to have that clunk still be there.
Do you get the clunking noise when turning the wheel at really low speed, say backing out of a parking spot?
Adding to an already old thread...I have similar issue, pretty loud banging over some of those rather unavoidable lines the road. Pretty loud. My only conclusion has been sway bar hitting the body? I however have no camber plates.
My guess would be the top nuts on your front or rear struts aren't tightened down fully. We had some loud clunking from the rear once when the nut wasn't sufficiently tightened. Now there just the regular occasional clunks from the solid Vorshlag camber plates or possibly the spherical endlinks. Never did bother to figure out which one it was.
Sorry about a late reply, but the 3 nuts that mount the perch to the body or the very center nut with the damper adjustment inside it? if youre speaking of the latter that just spins when you try and tighten it. The other three nuts are tight. I'm kind of lost and getting rather annoyed with them.
yep, that shaft that the top nut tightens down on, is shaped liked an allen wrench in the middle. Use the allen wrench to hold the shaft still against the tightening of the top nut. KW specs say only like 30 lbs/ft IIRC...what I did was basically back the bottom spring perch close to off, compress the spring, and then tighten the top nut down to the stop on that shaft. then put it all back together.
The Allen key, usually 6mm is in the center of the top nut. This is the preload on the top spherical bearing. If you haven't tightened it, that is your problem. Hold with 6mm Allen and tighten nut.
Thank you guys, that seems to have done the trick. I need to borrow a friends driveway to get the rears done. I still have the good loud THUD over speed bumps at my complex, but the road noise is gone. Is this the sway bar hitting the body? I purchased this car with the coilovers already on it. I'm really close to ditching these for a new set and starting from scratch so I can go through the process myself and know everything is right.
daviday
Sep 25, 2015 01:31 AM
