Suspension Ohlins installed!!
Old Jun 8, 2013 | 05:40 PM
  #51
ra2fanatic's Avatar
ra2fanatic
Originally Posted by Inkw8ll
Very nice wheels, what are the specs?
17x7.5 +40 offset.
On a side note, I think I got shafted by timwu who sold me his meth kit. Not a single posi-taps so I can't even tap into the ECU until I resolve the situation with him. 2nd time being shafted by him on this kit..
Old Jun 9, 2013 | 05:31 AM
  #52
THE ITCH's Avatar
THE ITCH
ra2fanatic
That is correct. The arms should be flush with the bar. The setup was designed with the correct overall length to give you the needed clearance and to keep your end links in a vertical position.
Just in case you do not find any wood give me a call should something change.
Steve
[QUOTE=ra2fanatic;3754265] Are the ends suppose to be flush to the end of the bar? I'll give tarett a call to confirm with them. This setup is here to stay. All these parts were bought with the intention of the third time being the charm. But I don't know I'll knock on wood
Old Jun 9, 2013 | 10:14 PM
  #53
ra2fanatic's Avatar
ra2fanatic
Got the panels and diffuser back up today. I'll work on the swaybar/endlinks tomorrow
Old Jun 10, 2013 | 01:39 PM
  #54
ra2fanatic's Avatar
ra2fanatic
[quote=THE ITCH;3754653]ra2fanatic
Steve
Talked to Tarett, and the arms do not have to sit flush with the end of the bar. The threading is there for the adjustment for your car. Your GP may install the same was as an R56, but the way the bar is aligned with the endlinks do differ. Had I adjusted the arms to be flush the endlinks would look like this \ / respectively. It would not be vertical as you mentioned.
And again, I asked about the endlinks, they don't have to be absolutely vertical, but they are relatively straight. The links were shortened to allow the swaybar arms to relatively parallel to the ground. I didn't bother taking a picture, but it is at this point, set.
Old Jun 12, 2013 | 08:10 PM
  #55
ra2fanatic's Avatar
ra2fanatic
Originally Posted by v10climber
We started with the Alta arms which were kind of noisy and not SCCA STX legal so we moved to the H-sports. They seem pretty solid. The only complaint I have is the jam nuts tend to loosen up if you don't tighten them down really well. And I had to buy a big wrench to tighten them with. 1 1/8" if I remember correctly. If you put a dab of threadlocker on it I'm sure they wouldn't go anywhere but we probably change the alignment once a month and I don't really want to be fighting against the threadlocker all the time
You were right about the jam nuts coming loose. I just caught my passenger side control arm really loose, maybe around -3.x so I'll jack up the rear tomorrow and set it back to stock again. Alignment is scheduled for tomorrow.
Old Jun 13, 2013 | 03:13 PM
  #56
ra2fanatic's Avatar
ra2fanatic
Got my alignment done. Really aggressive, but damn the grip that's up front is really noticeable now. Before I ran -1.5 front and -2.0 rears because of stance from my CCW's, but this....wooooo
-3.1 front
-2.3 rear
Old Jul 21, 2013 | 07:50 AM
  #57
g35mt's Avatar
g35mt
-3.1 front
-2.3 rear
Man..next time when u r in Orange County..hit me up..want to check your car. Do you have a picture of your car with the se37k? That is a sweet rim..one of my favorite from Volk.
Old Jul 21, 2013 | 08:12 AM
  #58
ra2fanatic's Avatar
ra2fanatic
Sure, you're welcome to visit me in El Monte as well. I'm always at my friends shop so you can always catch me there.
Crappy iPhone pic the day they went on.
@ the track.
Old Jul 21, 2013 | 12:18 PM
  #59
g35mt's Avatar
g35mt
i will pm you with my information. I am looking to put rsb, rear control arm, and kw v1 next week. I might just go down El Monte the following week to check out your car.
I've been looking for some nice wheels but no luck. Almost bought the c20 on here that you comment but he end up selling locally..bloody. Also look into se37k as well.
One thing i hate about mini is the selection of nice rim really not easily available in the used market. I mean i see some nice bbs lm and hre for audi, bmw and other higher end car for good price, but mini just very hard to find.
Old Jul 21, 2013 | 12:31 PM
  #60
Inkw8ll's Avatar
Inkw8ll
I've seen 5 lug MINIs, will a conversion help?
Old Jul 21, 2013 | 12:58 PM
  #61
ra2fanatic's Avatar
ra2fanatic
Nice nice. Well it looks like you're going in the right direction with everything so far. HRE for MINI is like $1500 a wheel before customization. I know I can get it down to 4, but their selections don't appeal to me that much. Those C20's I were told were trashed, hence my continued comment on that post ended on that only comment. Refurbing them would have pushed me more than I want to spend on wheels at the moment.
I would love to get another set of CCW's (3rd set -_-) but the front would look like **** because I'd have to clear my BBK and when I did have it, I had to push it out so much that it rubbed everywhere I went and it was horrible. 18x8 +20 offset in the front was just too much for me. If I did get another set, the fronts probably wouldn't even have a lip at all, which I don't know....doesn't look good in my head.
The SE37K's are hard to find since they've been discontinued for years, I know some shop has a set down in OC for like $2400, but damn, for that money I'd rather get some Advans (which I'll get later this summer). LM's just don't look that good on a MINI imho. They're 17s, but they look much smaller because of the face design.
If doing an adapter, the offset will be horrible and you'd still be limited yourself. Might be better, but more expensive, to retap the wheel bearing into a 5x120 if that were the case. Ducks did that and I wanted to do it too, but it just wasn't a cost effective method for me since I'd have to also get new hats for my stoptech and redrill the rears, etc etc.
Old Jul 21, 2013 | 01:25 PM
  #62
g35mt's Avatar
g35mt
You are correct on the LM. i had it on my b6 s4 19 inch. The rim still look small even at 19 inch. Imagine 17, really small. Ok..LM out.
Well now that you have mentioned about the c20, glad the seller sold locally. Just something about me and mesh..love those. I had Champion Motorsport rg40 on my s4, love those mesh.
On another note, the retap...how much do you estimate it will cost to retap?
the ccw, they sweet but sad part is i had seen one of STI and it was totally done so distasteful that really destroy the beauty of it.
Old Jul 21, 2013 | 01:45 PM
  #63
ra2fanatic's Avatar
ra2fanatic
I think 19" LM's look good though. They have a much better lip than for the MINI so at least it should have looked a lot better. Between the BMW I had and now the MINI, Volks have been my primary wheels I always go back to. Knowing that they're amazingly light and forged brings me back to them...
I'm not sure how much a retap would cost, the wheel bearing itself is around $100 each I think? Then a shop has to drill and thread the hubs, so I'm not sure what price range that'll fall...pm Ducks and I'm sure he can give you a ballpark price how much he got it done for.
As for CCW's. Here were the 2 sets I had. 1 in anodized gold and then anodized red. The red looks waaaaaay better in the end because of the swiss finish.
Old Jul 21, 2013 | 02:32 PM
  #64
silhouette88's Avatar
silhouette88
^^^damn that looks good! Nice job!
Old Jul 21, 2013 | 02:39 PM
  #65
g35mt's Avatar
g35mt
+1...
dang that looks sweet. i probably look for volk..price seems reasonable.
BTW, which of the advan rim u thinking of? RSD?
Old Jul 21, 2013 | 04:09 PM
  #66
ra2fanatic's Avatar
ra2fanatic
+1...
I've seen the RSD's on one of the DuelL AG cars and not a huge fan. I'm on the fence between RS or RZ. They'll get powercoated a different color when they arrive though.
Very close to this color...
http://www.m3post.com/forums/showpos...69&postcount=1
And can be seen in September's issue of Super Street (Friend's BMW)
http://www.e90post.com/forums/showpo...&postcount=428
Old Jul 21, 2013 | 04:49 PM
  #67
g35mt's Avatar
g35mt
Between the RS and RZ...man tough call..both are nice. I think the RZ looks better. At least it less busier looking. Less spoke compare to the RS.
Your friend place, wouldn't happen to be motor werks? nicely setup. Nice setup but the wings..me not a big fan of wing that big..i know i know..that is not what she said..hehehhe
i think my mind set to the RS-D..now gonna find some deals on that baby.
Old Jul 21, 2013 | 04:54 PM
  #68
ra2fanatic's Avatar
ra2fanatic
On the old E92 when I had RS... Yes, LTMW. I'm always there chillin' and helping. It's a full WTCC body conversion. 600whp E90 single turbo. He already sold the car and has an E92 M3 ready for Liberty Walk conversion with ESS supercharger....the guy has deep pockets...lol.
Old Jul 21, 2013 | 05:29 PM
  #69
g35mt's Avatar
g35mt
Funny..just did google search on LTMW...LT as i assume is the guy name. Sounds like vietnamese to me..i am as well.
THe RS does look nice on your e92. BTW, why did you chose mini instead of keeping your e92?
[/URL]
Old Jul 21, 2013 | 05:50 PM
  #70
Inkw8ll's Avatar
Inkw8ll
What's the rumor with BMW M1 hubs being swappable?
Old Jul 21, 2013 | 06:33 PM
  #71
ra2fanatic's Avatar
ra2fanatic
Yup, Long Tran is co-owner. The BMW was a big fat lemon. Fuel pump replaced 3 times, so I lemoned it. Always wanted a MINI.
I'm not sure, no one hasn't tackled that project and I don't think I'll be the one doing it
Old Aug 26, 2013 | 07:29 AM
  #72
brightside's Avatar
brightside
ra2fanatic, mind share what spring rate the ohlins are setup with?
I'm also after a 5 bolt conversion in the near future. I have the ability to drill them and once setup to do one set its not hard to do a second set.
Old Aug 26, 2013 | 07:49 AM
  #73
ra2fanatic's Avatar
ra2fanatic
#400 front and #285 rear (these are the springs shipped with the Ohlins).
That's fantastic that you're capable of drilling for 5 bolt conversions. I contemplated doing that for such a long time that I finally gave up. Having to redrill everything from my rotor hats to the hubs and finding 5x120 with proper offsets, it just doesn't seem ideal for me. It's not like I own the tools to do it and even if I did, too much downtime getting it done, so I'd rather not.
Old Aug 26, 2013 | 08:09 AM
  #74
brightside's Avatar
brightside
Thanks, i'm running #450 in the front and #250 in the rear currently and looking to step up to #350 in the rear to get rotation out of the rear end.
If i did the 5 bolt conversion i would do it to a set of brand new bearings and just swap all at once. I couldn't afford the downtime either as this is my daily driver.
Old Aug 26, 2013 | 08:18 AM
  #75
ra2fanatic's Avatar
ra2fanatic
Ah okay. With the #350, you don't think it'll compromise your daily drivability? Seems a lot of people point at Ohlins and say the money isn't well spent because the spring rate isn't very good for track, but forget it's Road and Track. I've considered running some Hypercoils, but I love the ride quality now that even after I've set it to the stiffest setting on the track, the compliance is noticeable.
